Wastegate spring size and MBC questions
Old Aug 25, 2005 | 07:50 PM
2LiterTurboSeR's Avatar
Default Wastegate spring size and MBC questions
Running a 44mm wastegate on my setup, I have been told that if I am running a Manual Boost Controller, that the MBC won't be able to change the boost if I am running anything over what the wastegate spring is at?
Reason being, I want a 10 psi spring, no wastegate when I'm just cruising around at 6 psi, and then turn the boost up to 15+ when I'm racing. I want to be able to turn the boost up, and I've been told I can't. Is this true?
Also, what is the advantage of a larger psi wastegate spring? No one I know seems to be able to explain this to me.
Thanks!
Old Aug 25, 2005 | 08:01 PM
beepy's Avatar
Default Re: Wastegate spring size and MBC questions (2LiterTurboSeR)
You can increase boost over what the wastegate is rated at but cannot reduce it.
So if you have a 10 PSI spring you will run 10 PSI with no MBC. With a MBC you can easily turn it up to 15 PSI. However, you cannot turn it down to 6 PSI.
A MBC can only increase boost about 50% over the spring rating safely, so you want a larger spring if you are going to run more boost.
Old Aug 25, 2005 | 11:04 PM
vaporboy12's Avatar
Default Re: Wastegate spring size and MBC questions (beepy)
im running a 9psi spring and boosting 20psi+ witha mbc no problem here
zbower7
Feb 6, 2004 09:48 AM
Cyber ITR
Jan 19, 2004 03:38 AM
1 POINT 8
Jan 13, 2004 04:16 PM
Spoold_R
May 12, 2003 06:21 PM
wonny
May 30, 2002 03:18 PM
