Std headgasket size fits overbore?
Old Aug 25, 2005 | 06:05 PM
PogKai's Avatar
Default Std headgasket size fits overbore?
Let's say.. will a 81mm headgasket will work a block bored to 82mm?
Old Aug 25, 2005 | 08:39 PM
onepoint6i's Avatar
Default Re: Std headgasket size fits overbore? (PogKai)
yes
Old Aug 26, 2005 | 11:30 AM
civicross's Avatar
Default Re: Std headgasket size fits overbore? (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
How?
The headgasket will hang into the combustion chamber, possible hitting the piston, and causing hot spots for pre ignition.
Old Aug 26, 2005 | 12:22 PM
R-Toyz.com's Avatar
you should be good till 81.5 bore...assuming it is an oem gasket
Old Aug 26, 2005 | 02:46 PM
PogKai's Avatar
well it's for a B20.. the headgasket is a Golden Eagle 84mm (OEM) but I have to bore to .40 (85mm).
Old Aug 26, 2005 | 04:30 PM
onepoint6i's Avatar
Default Re: Std headgasket size fits overbore? (civicross)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">
How?
The headgasket will hang into the combustion chamber, possible hitting the piston, and causing hot spots for pre ignition.</TD></TR></TABLE>
<FONT SIZE="5">
what do you mean how?? because that how HONDA made them...
I'm 100% postive...i've used them several times with 82MM pistons
</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom &raquo;</TD></TR><TR><TD CLASS="quote">you should be good till 81.5 bore...assuming it is an oem gasket</TD></TR></TABLE>
no!!!!! 82MM!!
Old Aug 26, 2005 | 04:38 PM
onepoint6i's Avatar
Default Re: (PogKai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PogKai &raquo;</TD></TR><TR><TD CLASS="quote">well it's for a B20.. the headgasket is a Golden Eagle 84mm (OEM) but I have to bore to .40 (85mm).</TD></TR></TABLE>
you should have asked that in the first place! your trying to compare apples to oranges...
depending on how golden eagle made the gasket you will probably not be able to use it...you need to check with them for sure....or measure it with a vernier caliper..
Old Aug 27, 2005 | 05:29 PM
R-Toyz.com's Avatar
no!!!!! 82MM!!</TD></TR></TABLE>
Hey...go easy and take your medication. I was stating how far an oem gasket would go in terms of bore size (assuming its a b16 / b18).
Old Aug 27, 2005 | 07:55 PM
onepoint6i's Avatar
Default Re: Std headgasket size fits overbore? (rtzcom)
Hey...go easy and take your medication. I was stating how far an oem gasket would go in terms of bore size (assuming its a b16 / b18).</TD></TR></TABLE>
Yeah i know, and your statement is wrong; sorry to say.
Old Aug 27, 2005 | 10:16 PM
R-Toyz.com's Avatar
Do you have proof that the gasket does not have any overhang at all in an 82mm bore? Just to prove me and civicross wrong.
Civicross pretty much has access to almost any size headgasket and their range of applications. In my experience the gasket was pretty much maxed out in an 81.5mm build, and if ever I did an 82mm bore, there was no way the gasket would have no overhanging material.
Remember there are 81.5 OEM pistons, but there are no specific 81.5 OEM gaskets, stock and OEM OS bore shares the same gasket, no more no less.
Are you sure you're talking about an OEM headgasket and a true 82mm bore?
I am hoping someone else could chime in and clarify this.
Old Aug 28, 2005 | 01:09 PM
ThatsMyEG's Avatar
Default Re: (rtzcom)
Id like to know if a oem head gasket would work on a b20 84.5mm bore?
Old Aug 29, 2005 | 09:13 AM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom &raquo;</TD></TR><TR><TD CLASS="quote">Do you have proof that the gasket does not have any overhang at all in an 82mm bore? Just to prove me and civicross wrong.
I am hoping someone else could chime in and clarify this.</TD></TR></TABLE>
Dude, read above...I HAVE USED SEVERAL STOCK OEM HONDA HEAD GASKETS ON "TRUE" 82MM BORE'S...why is that so hard to understand?
If your so undecisive, why dont you grab yourself a vernier caliper and measure for yourself.
you do realize how much 1mm is right?
Old Aug 29, 2005 | 09:19 AM
GUILOTINE's Avatar
Kill Gil
Remember there are 81.5 OEM pistons, but there are no specific 81.5 OEM gaskets, stock and OEM OS bore shares the same gasket, no more no less.</TD></TR></TABLE>
Im 100% sure that Honda doesn't offer 81.5 oversized pistons for B-series, only 81.25. If you dont believe me call your local honda dealership and talk to a knowledgable parts guy. If you need to go .5 over you need to buy aftermarket "oem" style Pistons from manufacters like Top flight or Rock etc.
Old Aug 29, 2005 | 09:26 AM
R-Toyz.com's Avatar
Default Re: (GUILOTINE)
And I stand corrected Gil re: the OEM OS bore. Got any thoughts on the topic? Any experiences on how far a stock HG will go?
integraboosted
Oct 3, 2007 10:12 AM
Nisif
14
Mar 12, 2006 11:00 AM
Master23
Mar 8, 2006 01:18 PM
Turbocivic94
Feb 26, 2006 02:18 PM
Cyber ITR
Nov 16, 2005 11:37 AM
