SHIFTING PROBLEMS.... EG W/ LS SWAP.. **please look**
Whats up guys, ... For some reason it is hard to get my tranny into second gear on a high rpm shift...You have to pull the shifter into second really hard to get it to go in, and when it does there is NO grinding what so ever...The tranny seems to be in perfect shape otherwise....The shifter rod is stock with stock bushings as well...Is it possible I have a bent shifter linkage or something????Any help would be great at this point...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnShiwota »</TD></TR><TR><TD CLASS="quote">is it a factory linkage? in good shape?</TD></TR></TABLE>
Yes, factory linkage...It appears to be in good shape other than where the roll pin slides through...It appears to be slightly boogered up therefore allowing some play right at the joint, but I dont think that would cause a first gear lock out like its doing....
insidious408
May 26, 2006 11:48 AM
