tial wastegate gasket
Old Aug 24, 2005 | 09:49 PM
Turbo_Mike's Avatar
Default tial wastegate gasket
Can tial 38mm wastegate gaskets be had anywhere else besides on line. I sorta need one asap and was wondering if i could find anything suitable from a napa or what. LIke a high temp make a gasket thing?
Mine got all fried out and leaks real bad.
Old Aug 24, 2005 | 09:55 PM
AspectIndustries's Avatar
Default Re: tial wastegate gasket (MIKE JONES)
Just remove the gasket and run without. Im sure you will be fine.
Old Aug 24, 2005 | 10:02 PM
vaporboy12's Avatar
Default Re: tial wastegate gasket (synik)
yeah you dont need a gasket there
Old Aug 25, 2005 | 02:28 AM
Turbo_Mike's Avatar
Default Re: tial wastegate gasket (vaporboy12)
Old Aug 25, 2005 | 02:31 AM
GWInquisitor14's Avatar
ya i just had the same problem, i used some Permatex ultra copper RTV silicone
here ya go
https://honda-tech.com/zerothread?id=1348917
Old Aug 25, 2005 | 03:18 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: tial wastegate gasket (GWInquisitor14)
i wouldn't suggest using the gasket supplied with tial wastegates, because its made of a paper-like material and will burn. i'd just run without it, but if you plan on using a gasket make sure to get a metal one.
Old Aug 25, 2005 | 04:29 AM
KeyserSoze's Avatar
Default Re: tial wastegate gasket (AzntaggeR)
Use a metal one or a chesterfield garfoil (its like a carbon gasket with ss core, good ****) type one, you can get the latter from mcmaster. GL.
Old Aug 25, 2005 | 05:35 AM
Turbo_Mike's Avatar
Default Re: tial wastegate gasket (KeyserSoze)
Thanks guys. I'll try running without it and see if it still leaks. Then i'll either try to make one or use some high temp rtv. [ stupid bolts keep backing out ]
Old Aug 25, 2005 | 06:38 AM
JDM-Civic-Hatch's Avatar
Yeah, i had same prob. my gassket fired and leaked like whoa. just take the gasket out and run it without. mine sealed and has no leaks.
-Chris
Old Aug 25, 2005 | 06:47 AM
BoostedEG6's Avatar
Default Re: (JDM-Civic-Hatch)
yeah I had the same problem with the bolts on my turbo....... just got to use a longer bolt then put it on and put a lock washer with another bolt on the other end. havent had a problem since
Old Aug 25, 2005 | 06:55 AM
tuoniz's Avatar
That gasket is worthless
Vinhtran17
May 12, 2004 02:21 PM
XBoostedAccordX
Oct 18, 2003 09:31 PM
Rain_man
May 9, 2003 03:32 AM
HondaCutter
Sep 9, 2002 01:11 PM
Etylorcen
Feb 24, 2002 01:39 PM
