b18a1 in to eg hatch questions??? SEARCHED
Old Aug 24, 2005 | 06:49 PM
dek1mfk's Avatar
Default b18a1 in to eg hatch questions??? SEARCHED
ok im putting together a b18a1 swap into my 92 dx hatch, i have the engine 93 b18a1, 95 gsr hydraulic tranny,00' si shift linkage, pr4 ecu, i need the engine harness, now i was told i cant use the 93 thats already on it, can i use my stock harness, if so what will need to be modified? also my car was automatic but i swapped out the auto tranny and put in the lines, i was told i would need to cut or weld the frame to make it fit is that true if so can someone explain in detail what i need?
Old Aug 24, 2005 | 07:16 PM
dgmorr's Avatar
Join my thread. Sounds like we're basically on the same road. I can also use some tips that I wouldn't think of myself.
https://honda-tech.com/zerothread?id=1348992
Old Aug 24, 2005 | 09:20 PM
dek1mfk's Avatar
Default Re: b18a1 in to eg hatch questions??? SEARCHED (dek1mfk)
bump
Old Aug 25, 2005 | 09:10 PM
dek1mfk's Avatar
bump again!!!!
Old Aug 26, 2005 | 08:41 AM
dek1mfk's Avatar
Old Aug 26, 2005 | 11:00 AM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote">ok im putting together a b18a1 swap into my 92 dx hatch, i have the engine 93 b18a1, 95 gsr hydraulic tranny,00' si shift linkage, pr4 ecu, i need the engine harness, now i was told i cant use the 93 thats already on it, can i use my stock harness, if so what will need to be modified? also my car was automatic but i swapped out the auto tranny and put in the lines, i was told i would need to cut or weld the frame to make it fit is that true if so can someone explain in detail what i need?</TD></TR></TABLE>
Yes you can use your stock wiring harness. Nothing needs to be modified to use the stock harness.
Also, you dont need to weld anything. If your going from Auto &gt; 5-spd conversion you might have to cut or drill a hole to get some space where the shifter is but I don't think that might even need to happen.
Pretty much your swap is drop in and go, but make sure you get the proper mounts
Old Aug 26, 2005 | 01:01 PM
(puma)'s Avatar
yep, you can use your stock harness, also for future reference, if you were to go ls vtec you could also use your stock, you would just have to have someone wire in your vtec
Old Aug 26, 2005 | 02:37 PM
Targa250R's Avatar
be professional
Default Re: b18a1 in to eg hatch questions??? SEARCHED (_B_Series_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _B_Series_ &raquo;</TD></TR><TR><TD CLASS="quote">yep, you can use your stock harness, also for future reference, if you were to go ls vtec you could also use your stock, you would just have to have someone wire in your vtec</TD></TR></TABLE>
All '92 hatchbacks already have the wiring in place for VTEC, regardless of trim level.
Old Aug 26, 2005 | 03:32 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote"> also my car was automatic but i swapped out the auto tranny and put in the lines, i was told i would need to cut or weld the frame to make it fit is that true if so can someone explain in detail what i need?</TD></TR></TABLE>What you need is a auto--&gt;manual transmission mount from Hasport for around $175. Automatic and manual Civics/Integras have different transmission frame mounting points. Don't forget to run your wires for the reverse lights and the clutch engagement wire (@ clutch pedal sensor) so that it will "function" like a 5-spd Civic from the Honda factory.
Old Aug 27, 2005 | 12:45 PM
dek1mfk's Avatar
Default Re: b18a1 in to eg hatch questions??? SEARCHED (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">What you need is a auto--&gt;manual transmission mount from Hasport for around $175. Automatic and manual Civics/Integras have different transmission frame mounting points. Don't forget to run your wires for the reverse lights and the clutch engagement wire (@ clutch pedal sensor) so that it will "function" like a 5-spd Civic from the Honda factory.</TD></TR></TABLE>
so theres no way to do it without that mount since im low on cash????
Modified by dek1mfk at 10:11 PM 8/29/2005
Old Aug 29, 2005 | 06:59 PM
dek1mfk's Avatar
bump!!
Old Aug 29, 2005 | 07:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote">so theres no way to do it without that mount since im low on cash????
Modified by dek1mfk at 10:11 PM 8/29/2005</TD></TR></TABLE>
Correct. Like I also said you need to buy the custom mount. If you don't then your tranny will sit lower and your drive shaft will pop out under load
Old Aug 30, 2005 | 01:50 PM
dek1mfk's Avatar
Default Re: b18a1 in to eg hatch questions??? SEARCHED (Mr.RHTuner)
is there a site i could buy the mount from??
Old Aug 30, 2005 | 01:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote">is there a site i could buy the mount from??</TD></TR></TABLE>
http://www.jdmshit.com
read
jikespingleton
Feb 27, 2007 06:39 PM
devang230
Oct 10, 2005 11:18 AM
honda2k
Sep 6, 2004 06:56 PM
PuiPui
10
Aug 26, 2004 11:26 AM
Tad
Oct 8, 2003 03:03 AM
