turn signal problems
Old Aug 24, 2005 | 03:17 PM
mdaby3's Avatar
Default turn signal problems
the situation: 1995 Accord EX the turn signals are working intermittently, making a "buzzing" noise inside. It happens almost every time we turn them on, but will occasionally stop by itself. When the buzzing noise stops, the turn signals work., but only for a few seconds, then more buzzing. Any idea?
Old Aug 24, 2005 | 03:29 PM
YeuEmMaiMai's Avatar
Default Re: turn signal problems (mdaby3)
I have the same problem when my car is cold. I think it may be the relay but I am too lazy to check as it only does it for about 1 sec before they work.
Old Aug 24, 2005 | 03:34 PM
mdaby3's Avatar
Default Re: turn signal problems (YeuEmMaiMai)
thanks for the info. I wish I could check it myself, but that's really not a good idea(very auto challenged)!
I just hope it doesn't cost much to fix it. I hate having no working turn signals--it's illegal and dangerous
Old Aug 24, 2005 | 03:41 PM
it's easy my friend it's just a matter of knowing where the relay is, removing it and replacing it. (After you test to find the fault)
Old Sep 7, 2005 | 11:27 AM
99problemssss's Avatar
YO.... i've never had to change out the relay so i dont know where it is or what it looks like. I'm pretty sure that's the problem with my LX. Anybody??
Old Sep 8, 2005 | 11:10 AM
deserthonda's Avatar
Default Re: turn signal problems (99problemssss)
relay is located in the underdash fuse box......
Old Sep 12, 2005 | 11:14 AM
Default Re: turn signal problems (deserthonda)
Ok, replaced the relay and still nothing. all fuses are good. Are there any other electric components that would affect the turn signals?
Old Sep 12, 2005 | 04:45 PM
it's the multi function switch and that is not so easy to replace........that is why I have not botherd with fixing mine yet.
lien
24
Nov 30, 2021 04:10 PM
bobbyj59
Apr 7, 2012 11:14 AM
polaris80
Apr 20, 2007 04:13 AM
Ralph Wiggum
Mar 19, 2003 08:17 PM
