Would you buy an S with 70,000 miles?
When almost all the S2000s available have more like 20,000 miles on them, would you, (ifyou got a great price) pay for an S2000 with 70,000 miles?
Normally, it would be hard to do, but considering its a Honda?
Why not? 70,000 miles on a Honda is like 30,000-50,000k on most cars, i'd say regardless of car, if its a honda, 70,000 is still a fairly decent mileage to consider purchasing.
I'd certainly have it checked over though...good $80 safety net.
The motor is supposed to be good until 107k miles, if it stayed stock. On 70k I'd at least check compression/leakdown. Clutch would be a suspect. A friend's S with 56k had its O2 sensors give out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyWayIsSideways »</TD></TR><TR><TD CLASS="quote">The motor is supposed to be good until 107k miles, if it stayed stock. On 70k I'd at least check compression/leakdown. Clutch would be a suspect. A friend's S with 56k had its O2 sensors give out.</TD></TR></TABLE>
motor good til 107k? explain that...plenty of ppl over that mileage on their motors
I meant as far as the first scheduled tune up for the motor is 107K miles. For other cars its usually 60k or 75k. Even then its just a tune up: new plugs, cam chain adjustment, etc.
I found one and the guy wants $24,000 CDN... I think thats closer to $20,000 USD right now
and I'd have to pay 15% more in taxes
I'm thinking it might just be the time to take the plunge into S2000 territory
I know once it gets a little colder around here I'll be able to pick one up for cheaper
i have 88k on mine as of yesterday... the only problem I've ever had was with the rear wheel bearing. And that was because I never got the tsb done for the rear axle nut. But to answer your question $15-16k would be a good price.
