??? [B]SS fuel line[/B] question ???
Old Aug 24, 2005 | 07:00 AM
JICEK9's Avatar
Default ??? SS fuel line question ???
I am in the process of upgrading to SS fuel lines and have a question for people that have done this.
Heres the plan... -8an line from the stock fuel filter to STR fuel rail. from STR rail I will use -6an line to connect to SARD fuel pressure regulator. from regulator to return -6an.
Heres the question... what is the oulet size of the <U>OEM fuel filter</U>?
Old Aug 30, 2005 | 11:14 PM
YiNYaNg's Avatar
Default Re: ??? SS fuel line question ??? (JICEK9)
Ditch that FMU you got and get a EMS,DSM 450cc injectors(always dirt cheap $50.00-$70.00),10watt 10ohm resistors or obd0 resistor box + get it tuned by Shane @ Elite and your superchargered sohc vtec will be running at its best....
Old Aug 31, 2005 | 03:06 AM
BoOstedEM1's Avatar
Default Re: ??? SS fuel line question ??? (H-T)
SO i dont think that answered anything remotely to his question. I dont know the size but good luck..
Old Aug 31, 2005 | 03:09 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: ??? SS fuel line question ??? (BoOstedEM1)
OH man, I can't remember. I think it's -6an.
Old Aug 31, 2005 | 10:29 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">Ditch that FMU you got and get a EMS,DSM 450cc injectors(always dirt cheap $50.00-$70.00),10watt 10ohm resistors or obd0 resistor box + get it tuned by Shane @ Elite and your superchargered sohc vtec will be running at its best.... </TD></TR></TABLE>
has NOTHING to do with my question
Old Aug 31, 2005 | 10:31 AM
JICEK9's Avatar
Default Re: ??? SS fuel line question ??? (litterbox)
the CORRECT answer is here on this link
https://honda-tech.com/zerothread?id=1349700
thanks for everybody that tried tho
Old Aug 31, 2005 | 10:35 AM
rob...'s Avatar
you could just cut off the compression fitting and take it to where your going to buy the fitting from and match it up. i think also you will have to use a special fitting, i'm not sure tho'. you need a AN flare male in stead of the usual compression style.
Old Aug 31, 2005 | 10:37 AM
litterbox's Avatar
Default Re: ??? SS fuel line question ??? (baseballinmyass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">the CORRECT answer is here on this link </TD></TR></TABLE>What's the correct answer? I didn't see it in the therad?
Old Aug 31, 2005 | 01:51 PM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">What's the correct answer? I didn't see it in the therad?</TD></TR></TABLE>
the seconed post. answers the question. infact, he allready sent me the part.
OMG THE GOGGLES
Jun 27, 2011 07:05 PM
eg6hatch
Aug 27, 2006 08:58 AM
JICEK9
Aug 25, 2005 12:37 PM
t3to4e
Mar 4, 2004 06:58 AM
turbogsr13z
Mar 18, 2003 05:26 PM
