Clutch Problem.. **HELP**
Old Aug 23, 2005 | 11:51 PM
Hella_Fresh's Avatar
Default Clutch Problem.. **HELP**
yesterday something happend with my tranny.
not sure what it is but i could throw it in gear without the clutch.. so im guessing it the clutch.
When i press down all the way on the clutch, nothing happends.. it doesnt go in gear at all. I adjusted the cable all the way.. still nothing happends. There is a Exedy clutch in there and i know its not old and worn out. I just dont know whats up.
Does anyone know whats wrong??
its a b16 tranny also
Old Aug 24, 2005 | 04:18 PM
Default Re: Clutch Problem.. **HELP** (sXekid)
anyone??
Old Aug 24, 2005 | 04:53 PM
cuz_ican's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">anyone?? </TD></TR></TABLE>
im not really understanding what happened....
Old Aug 24, 2005 | 07:46 PM
Default Re: Clutch Problem.. **HELP** (cuz_ican)
ok
i can press on the clutch pedal all the way, and i cant put it in gear. I adjusted the pedal all the way and still nothing happends. It doesnt go in gear with the clutch.. but then when i get it rolling i can put it in gear, but not using the clutch.
thats kinda a better explanation.
Old Aug 24, 2005 | 07:48 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">yesterday something happend with my tranny.
its a b16 tranny also</TD></TR></TABLE>
You adjusted the cable all the way? 92-95 civic's came with hydraulic clutch's..
Whats your setup.. IE: Motor,etc
I'm confused.
Old Aug 24, 2005 | 07:59 PM
Default Re: Clutch Problem.. **HELP** (Jimmy)
yea it was converted to cable tranny..
its a 2nd gen b16 with a b16 cable tranny. and the clutch is Exedy
Old Aug 24, 2005 | 08:39 PM
Jimmy's Avatar
Global Moderator
Bleed the clutch, check the clutch master cylinder for fluid leaking around it.
Old Aug 24, 2005 | 11:52 PM
RATED EG's Avatar
Default Re: (Jimmy)
might be your Throw o ut bearing...same **** happened when i broke mine
Old Aug 25, 2005 | 08:53 AM
cranberry's Avatar
yeah thats sounds right, i might be changing mine soon too. its playing some fucked up games with me.....
Old Aug 25, 2005 | 09:59 AM
1.8EG-T's Avatar
Default Re: (RATED EG)
Bleed the MC, look for leaks inside the car...then it might be your throw out bearing like mentioned before.
Old Aug 25, 2005 | 11:53 AM
Default Re: (1.8EG-T)
where is the clutch MC located?? would it happen to be on the right side of the engine bay? because there looks like there is alot of grease or somthing that i know is not supposed to be there.. or that just might be ANOTHER problem i have with this car
Old Aug 25, 2005 | 12:24 PM
smash fascism's Avatar
If he has a cable tranny then you wouldn't need to bleed the master cylinder. It sounds like a throwout bearing to me.
Old Aug 25, 2005 | 12:42 PM
Default Re: (smash fascism)
bump
harmonator84
Transmission & Drivetrain
Aug 28, 2008 10:14 AM
vietnamese0utlawz
Oct 11, 2006 04:53 PM
1FastCoupe
Apr 12, 2005 08:51 AM
KrispyKreme
22
Jan 10, 2005 11:57 PM
GapxGuy
May 11, 2003 08:20 PM
