what are the benefits between p30 and a p28?
Old Aug 23, 2005 | 11:35 AM
94hatchling's Avatar
Default what are the benefits between p30 and a p28?
i'm new to the whole "new world" of today's automotive, and still learning. less wires and no ecu compared to my other car.
so, benefits between a p30 and p28? any one over the other? i am currently running a p30 in my b16a2 swapped hatch, and have seen many different posts involving the p28. if i remember correctly, the p30 is out of a del sol? is that correct?
also, i will be adding hondata at some point soon hopefully, but am impatient and curious of adding a chip to my p30. could anyone tell me about the price and where i could pick one up? just trying to figure out my options.
thanks for any helpful input
Old Aug 23, 2005 | 01:13 PM
Default Re: what are the benefits between p30 and a p28? (94hatchling)
anyone?
Old Aug 23, 2005 | 01:15 PM
92HatchB16's Avatar
Getting a chip is always a good idea...Go to this website...
http://www.Locashracing.com
They do really quality chipping
Old Aug 23, 2005 | 01:20 PM
hatchi's Avatar
as for one thing
p30 is for dohc vtec cars
p28 is for sohc vtec cars
you will need to chip p28 to be able to run dohc motors. usually chips will eliminate knock sensor depending on which chip you use.
Old Aug 23, 2005 | 02:17 PM
Relic1's Avatar
both the P28 and P30 are chipable, both run the same processor internally.
the only real difference is the base map included in the factory rom and the knock sensor board in the P30.
Either ECU can be used to run any engine provided you chip them.
with your B16A you're better off with the P30 due to the factory rom matching the engine.
Old Aug 23, 2005 | 06:17 PM
jax si's Avatar
check out kenji... he is quite reputable. here's the link.. and visit his website.
https://honda-tech.com/zerothread?id=1300672
Old Aug 23, 2005 | 06:21 PM
EG6Krew's Avatar
You dont have to run knock sensor with a chipped P28, also they are more friendly to tuning!
Old Aug 25, 2005 | 02:17 PM
Default Re: what are the benefits between p30 and a p28? (EG6Krew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6Krew &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to run knock sensor with a chipped P28, also they are more friendly to tuning!</TD></TR></TABLE>
what would be the benefit of not running a knock sensor? isn't it there to, you know, sense knock? along with vtec, there to save the motor if there is knock and disable vtec? just wanted to clarify.
Old Aug 25, 2005 | 02:25 PM
Relic1's Avatar
the only advantage of the knock sensor is saving your engine if you hit a bad batch of fuel.
Old Aug 25, 2005 | 02:43 PM
Default Re: (Relic1)
then i'll stick with the p30 and the knock sensor... saving my motor sounds like a plus if you ask me. thanks for the replys.
RA-d15b-vtecp08
Engine Management and Tuning
Sep 9, 2015 08:51 AM
mental1
May 25, 2009 05:23 PM
B16CivicEX
Jul 27, 2006 09:44 AM
redline23
May 7, 2004 06:10 AM
TEGPOWER44
34
Jul 2, 2002 11:39 AM
