Rotor replacement!
Old Aug 23, 2005 | 11:34 AM
E-gg's's Avatar
Default Rotor replacement!
Hi all,
Its time to get them replaced. I am currently using cross drilled Brembos. Any other recommendation? I also plan to get a set of brake lines. What brands of brake lines do ppl. often use here?
94hatchling,
Sorry if my English bothers you? Anyway, my intention of this post is to see what's majority is using rather than "what's the best". I am not interested in finding whether drilled or slot is better...etc. But, thanks for your input. I'd appriciated.
Modified by E-gg's at 1:41 PM 8/23/2005
Old Aug 23, 2005 | 11:45 AM
94hatchling's Avatar
Default Re: Rotor replacement! (E-gg's)
english owns you
and to help... there have been a lot of people using brembo blanks, and seem to like them. i'm running baer cross drilled and slotted on mine and like it, and i couldn't beat the price. but to each his own.
and i'm sure if you searched, you would have found a lot... i seem to remember reading such a post quite recently. anyhow, good luck with your research.
Old Aug 23, 2005 | 12:48 PM
nub.96ek's Avatar
Default Re: Rotor replacement! (94hatchling)
I like the Russel lines, they have a clear coating over them and look very clean. Check Fast Brakes for rotors... cheap prices if you can get him on the phone.
Old Aug 24, 2005 | 08:55 AM
E-gg's's Avatar
Default Re: Rotor replacement! (nub.96ek)
nub.96ek,
Any more details on the "Fast Brakes"? Link?
Guess what I found on my Brembo rotors? It begins to crack! Thin hair lines around the holes.....
Old Aug 24, 2005 | 09:25 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-gg’s &raquo;</TD></TR><TR><TD CLASS="quote">
Guess what I found on my Brembo rotors? It begins to crack! Thin hair lines around the holes..... </TD></TR></TABLE>
Yes, that's what happens with cross drilled rotors. Drilling the holes creates stress concentration points, and sometimes microfractures, which eventually lead to cracking.
Get Brembo blanks. Less than $30 from ImportRP in the sponsors section.
Old Aug 24, 2005 | 09:52 AM
Crazydave's Avatar
Default Re: Rotor replacement! (AutoXer)
I'd just get some regular rotors
x-drilled will just give you problems
Old Aug 25, 2005 | 03:34 PM
E-gg's's Avatar
Default Re: Rotor replacement! (Crazydave)
Thanks. I am going to get either Brembo blanks or OEM. I think Brembo use better materials, rite?
KLackeyImages
12
Jan 26, 2022 07:54 AM
Sherrij
Suspension & Brakes
Jun 5, 2017 05:31 PM
spoonhatchblack
Suspension & Brakes
Feb 13, 2008 03:19 PM
mooseheads36
Honda Civic (2006 - 2015)
33
Apr 20, 2007 04:54 AM
TurboCoop
Sep 30, 2005 05:27 PM
