about b16 swap in my 95 civic...
Old Aug 22, 2005 | 03:35 PM
andreysibiris's Avatar
Default about b16 swap in my 95 civic...
my car is not running well, i know that i have to oil change, fuel filter and sparks plugs, because the engine was a year and half in a garage, but i got some questions about behind the engina down there around the oil filter theres two smalls sensors one is next to the oil filter drivers side that i dont have any plug miss for it in the harness and the other one is on the top of the oil filter that i have a small cap with a single wire plug for that... what i have to do? my car is very slow, when im stop, the engine run perfect till 8500 rpms, but when i start driving the car goes down like 2 miles by hour.....3, 4 super slow!!!
Old Aug 22, 2005 | 03:37 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: about b16 swap in my 95 civic... (andreysibiris)
Those plugs are for the Knock Sensor and the Oil Pressure switch. MIGHT wanna hook those up.
Old Aug 22, 2005 | 03:46 PM
Default Re: about b16 swap in my 95 civic... (JDM_Ej)
but i dont need the knock sensor, right? i got a p28 ecu...
Old Aug 22, 2005 | 03:50 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
No you wouldn't but that is probably why it's running like ****, unless the P28 is programmed for the engine. P30 is what you should be running if you keep a stock ECU..
Old Aug 22, 2005 | 03:53 PM
mericbe's Avatar
OK *sigh* the Knock Sensor is the vital in the the engagement of Vtec. Hence the powerloss. It will and may sound like vtec is hitting but trust me it's not.
Old Aug 22, 2005 | 03:55 PM
Default Re: about b16 swap in my 95 civic... (mericbe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mericbe &raquo;</TD></TR><TR><TD CLASS="quote">OK *sigh* the Knock Sensor is the vital in the the engagement of Vtec. Hence the powerloss. It will and may sound like vtec is hitting but trust me it's not.</TD></TR></TABLE>Yeah this would be the case if he was actually using the right computer.. I know the P28 can work but only if its chipped.
Modified by HondaFanatic708 at 7:22 PM 8/22/2005
Old Aug 22, 2005 | 05:17 PM
Default Re: about b16 swap in my 95 civic... (HondaFanatic708)
i got my ecu chipped with a reprogrammable chip but i think that is something with the fuel..........because vtec kick in and i feel it.....but when i press deep gas the car start to running too slow.....
Old Aug 22, 2005 | 05:19 PM
Maybe they programmed the WOT too rich, get a wide band O2 sensor and a air/fuel meter. See if your running too rich at WOT..
jlfrnce
Oct 19, 2009 10:45 AM
skimb37
Jan 1, 2009 08:31 PM
CaptivaBlue
Oct 6, 2004 03:27 PM
roc
Apr 11, 2003 08:38 PM
mr_mbuna
Feb 8, 2003 06:49 AM
