clutch master cylinder
Old Aug 22, 2005 | 12:16 PM
ATS*Mark's Avatar
OG triple OG
Default clutch master cylinder
how do you know when your clutch master cylinder is going bad or is bad? no clutch pedel at all?
Old Aug 22, 2005 | 02:26 PM
Quetzolcotl's Avatar
Default Re: clutch master cylinder (Hella_JDM)
what is happening to your car? you could try to blead the system and see if that helps.
Old Aug 22, 2005 | 02:57 PM
nocturnaldragon's Avatar
You could also have a leak in your line somewhere causing your proplem. Check all your lones and slave cylinder as well look for leakage around them both, check inside the car for the master if its leaking thats a tell tale sign its bad, otherwise they just dont go bad without some sort of sign like that.
Check for leaks and what not first, otherwise if it goes bad it just wont work it either wont let you push down or will go down and stay there aka no pedal at all. the no pedal could also be a sign of a leak and the stuck pedal could also be a collapsed line.
Hope I did my best to confuse you
Old Aug 22, 2005 | 03:21 PM
Lord Helmet's Avatar
Well when my clutch MC started to have moisture buildup around the MC, it was time to replace it. I didn't want to wait for it to start leaking to replace it. Preventative Maintenance > Corrective maintenance
Old Aug 22, 2005 | 03:40 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clutch master cylinder (Lord Helmet)
Yea Honda clutch master cylinders will usually start to leak on the inside of the car when they are going bad.
Old Aug 22, 2005 | 03:54 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: clutch master cylinder (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Yea Honda clutch master cylinders will usually start to leak on the inside of the car when they are going bad. </TD></TR></TABLE>+1
Old Aug 22, 2005 | 08:25 PM
1.8EG-T's Avatar
Default Re: clutch master cylinder (HondaFanatic708)
Wow...I don't have leakage, but my pedal comes back to the engagement point, then sticks for a moment, then comes up the rest of the way...what causes this...sorry to jack your thread, but we have similar problems.
Old Aug 22, 2005 | 08:44 PM
4DeepCivic's Avatar
Default Re: clutch master cylinder (1.8EG-T)
Bleed the whole fluid line, make sure you use new fluid and check for leaks
Old Aug 23, 2005 | 07:32 AM
tpr's Avatar
tpr
That "sticking" is usually due to the release bearing piviot shaft needing to be cleaned and regreased. The sad part is the transmission must come out to get to it.
Old Aug 23, 2005 | 09:55 AM
1.8EG-T's Avatar
Default Re: clutch master cylinder (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">That "sticking" is usually due to the release bearing piviot shaft needing to be cleaned and regreased. The sad part is the transmission must come out to get to it.</TD></TR></TABLE>
Wow, I just put the thing in and greased it not too long ago, about 3k ago to be precise. Oh well, the clutchmaster's started slipping on the dyno as well, so it has to come out anyway.
gen2tegboi
11
Jun 18, 2011 06:34 PM
Miracle11
Feb 13, 2011 06:38 PM
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
dartonh22
Jun 18, 2008 10:13 AM
S2k Hybrid
Mar 15, 2007 10:36 PM
