My tranny is acting up and my car wont go into gear! Help
Old Aug 22, 2005 | 11:56 AM
Rocks.'s Avatar
Default My tranny is acting up and my car wont go into gear! Help
My car is having some issues right now.
My car would not go into gear this morning. I would press the clutch and try to put it in 1st and it wouldnt budge, I also tried 1,2,3,4,5 and R and it wouldnt budge. I left the car on for about five minutes and tried once again. I pushed down on the clutch the most I could and it got into 2nd and I drove around the block in 2nd and it wouldnt come out of second. I turned the car off and started it again and now the car will go into gear but not smoothly it would take some elbow grease to get it into gear. Once again I turned the car on and off and the car goes into gear with not problem but I still did not drive it today because I was scared it will leave me stranded. What could cause this problem and what should I look for?
Old Aug 22, 2005 | 12:07 PM
komat's Avatar
Default Re: My tranny is acting up and my car wont go into gear! Help (Kobester)
can it go into gear while the engine is off??
spoonciv's Avatar
most likely your clutch is gone!! replace ur clutch...I am about 90% sure because I fix many cars that had the same problem as u.
Old Aug 22, 2005 | 12:10 PM
Rocks.'s Avatar
Default Re: My tranny is acting up and my car wont go into gear! Help (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">can it go into gear while the engine is off??</TD></TR></TABLE>
yes it will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonciv &raquo;</TD></TR><TR><TD CLASS="quote">most likely your clutch is gone!! replace ur clutch...I am about 90% sure because I fix many cars that had the same problem as u.</TD></TR></TABLE>
my clutch pedal squeaks any more help on this would be great.
Old Aug 22, 2005 | 02:21 PM
Quetzolcotl's Avatar
did your shifter fork get bent?
Old Aug 22, 2005 | 02:28 PM
92ehatch's Avatar
Default Re: My tranny is acting up and my car wont go into gear! Help (Quetzolcotl)
sounds like clutch to me.
my clutch squeaks too but not having that problem
Old Aug 22, 2005 | 02:47 PM
Rocks.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quetzolcotl &raquo;</TD></TR><TR><TD CLASS="quote">did your shifter fork get bent? </TD></TR></TABLE>
what causes em to get bent
Old Aug 22, 2005 | 03:05 PM
dirtysohc79's Avatar
my clutch also squeaks. I'm guessin its an indication that your clutch is going out. My buddy's car does the same thing.
Old Aug 22, 2005 | 03:12 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dirtysohc79)
Thats not your clutch sqeeking, its your clutch master cylinder.
honda305
14
Oct 6, 2009 09:11 PM
SkIp_Civic_Ek6
Apr 5, 2007 11:38 PM
paybac4223
Oct 28, 2002 03:01 PM
Mires
Sep 25, 2002 05:34 PM
