car hesitates when giving it throttle
Old Aug 21, 2005 | 10:00 PM
See Are X's Avatar
Default car hesitates when giving it throttle
Recently my car has been acting up. Here are some symptoms of my problem. I'll rev my car from idle till like 3k rpm, let go of the gas and rev it again, it'll hesitate before it starts to rev again. Also, while im driving, i'll shift around 3k and if I dont shift slow, I can feel the engine hesitate again.
The thing is, after the hesitation, the engine seems like it runs fine. It still pulls good up to 9psi. I just changed my plugs, cap and rotor, and oil. The car is untuned, running off of a chipped "NA" ecu(retarded timing from the dizzy to compensate for boost). I would like to say tuning is the problem, but my car has been running fine for a little over a year. Any other ideas???
Old Aug 21, 2005 | 10:01 PM
See Are X's Avatar
I checked my ignition timing, at idle its at 14degrees, where I had it for the past year.
a friend of mine says it could be running too rich...I don't understand how my fuel could change out of nowhere.
Old Aug 21, 2005 | 10:16 PM
OMG B16's Avatar
You've been running un-tuned for a year?
Old Aug 21, 2005 | 10:34 PM
JDM EJ1 95's Avatar
tahah.. holy **** get that ***** tuned...
part throttle tuning pwnz j00
Old Aug 22, 2005 | 01:40 PM
See Are X's Avatar
Default Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">tahah.. holy **** get that ***** tuned...
part throttle tuning pwnz j00</TD></TR></TABLE>
haha...ive been planning to, but money pwnz me even more...I dont see how it could be part throttle tuning anyways, its been running fine like that for over a year.
Old Aug 22, 2005 | 01:52 PM
Finest's Avatar
Default Re: car hesitates when giving it throttle (See Are X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">The car is untuned, running off of a chipped "NA" ecu(retarded timing from the dizzy to compensate for boost). </TD></TR></TABLE>
What the hell are you running for management? AFC hack? I'd say that's your first problem.
Old Aug 23, 2005 | 04:11 PM
See Are X's Avatar
Default Re: car hesitates when giving it throttle (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
What the hell are you running for management? AFC hack? I'd say that's your first problem. </TD></TR></TABLE>
No engine management
Old Aug 23, 2005 | 04:19 PM
EBP.EM1's Avatar
No engine management</TD></TR></TABLE>
thats your problem right there.
Old Aug 23, 2005 | 08:11 PM
See Are X's Avatar
Default Re: car hesitates when giving it throttle (1slow4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slow4dr &raquo;</TD></TR><TR><TD CLASS="quote">
thats your problem right there. </TD></TR></TABLE>
I dont see how the fuel maps or whatever it is just changed out of nowhere...it seemed like it was running fine for the first year the turbo kit was on.
Old Aug 24, 2005 | 03:01 PM
See Are X's Avatar
UPDATE:
I've changed the oil, plugs, cap, rotor, o2 sensor, fuel filter, and put some fuel system cleaner in it. None of those things were the problem. It ended up being a bad missing link. I also did a compression test on it, 145 across the board. Runs like a champ.
Old Aug 24, 2005 | 03:06 PM
mexicansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">UPDATE:
I've changed the oil, plugs, cap, rotor, o2 sensor, fuel filter, and put some fuel system cleaner in it. None of those things were the problem. It ended up being a bad missing link. I also did a compression test on it, 145 across the board. Runs like a champ that is going to get knocked the f..... ck out sooner or later</TD></TR></TABLE>
edited for truth, good luck running your car with a missing link
Old Aug 24, 2005 | 07:57 PM
See Are X's Avatar
Default Re: car hesitates when giving it throttle (mexicansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mexicansi &raquo;</TD></TR><TR><TD CLASS="quote">
edited for truth, good luck running your car with a missing link</TD></TR></TABLE>
Buy me hondata and tune my car, then maybe i'll have better luck than that missing link
RineRacing
Sep 26, 2005 10:51 AM
See Are X
Aug 22, 2005 08:28 PM
JordanCivic
May 5, 2005 07:03 AM
Antilag
Aug 27, 2004 06:26 AM
Grease Monkey
26
Nov 22, 2003 05:27 AM
