diff. between 92-95 and 96-00 turbo kits
well, i dont want to piece together a turbo kit, so im buying greddy, and i know that d series turbo kits are all almost universal, so i was wondering why the 92-95 kits were 1400, when 96-00 ex kits were 1850, and can i still use the blue box from 92-95 on my d16y7.....1996, thanks
The blue box from the 92-95 won't work with the 96-00 cars.
The fuel may be pretty close, but the ignition maps are way different.
If you're going to run your own CPU Controller (Uber/Crome/Hondata/AEM) I'd get the 92-95 kit, sell the blue box, get a P28, socket it, and run the Rom Controller of my choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">well, i dont want to piece together a turbo kit, so im buying greddy, and i know that d series turbo kits are all almost universal, so i was wondering why the 92-95 kits were 1400, when 96-00 ex kits were 1850, and can i still use the blue box from 92-95 on my d16y7.....1996, thanks</TD></TR></TABLE>
The 96-00 kits come with more. For example 320cc (could be off but I know it is 300cc or greater) injectors come with the 96-00 kits. I know there are other little differences. I would either sell teh blue box if you get the 96-00 and go with a chipped ecu OR just buy a 92-95 kit and ECU
yea i dont want to **** with my fuel manag. so i would love to just get larger injectors and the blue box and be done with it, for like a year or so till i get greater knowledge, but will it be okay to use the ex blue box on my cx y7....thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">yea i dont want to **** with my fuel manag. so i would love to just get larger injectors and the blue box and be done with it, for like a year or so till i get greater knowledge, but will it be okay to use the ex blue box on my cx y7....thanks</TD></TR></TABLE>
Nah. 92-95 ignition is way different than the 96-00 ignition. The car will stutter and run like crap for that year until you switch to a better program and get it tuned.
If you are not the well knowledge with turbo, then i wouldnt go turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">
Nah. 92-95 ignition is way different than the 96-00 ignition. The car will stutter and run like crap for that year until you switch to a better program and get it tuned.</TD></TR></TABLE>
i mean can i use the blue box from a 96-00 ex on my cx..?? thanks
i mean can i use the blue box from a 96-00 ex on my cx..?? thanks</TD></TR></TABLE>
The answer to that I honestly don't know. Don't cx's have the Y7 and the ex's have the Y8 heads? Both are 1.6Ls, correct?
The answer to that I honestly don't know. Don't cx's have the Y7 and the ex's have the Y8 heads? Both are 1.6Ls, correct? </TD></TR></TABLE>
yea, i have a y7 non-vtec, both are 1.6l's, but the y8 is vtec, soooo im not sure, i could just get a mini-me later on and use the blue box after that.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">
If you are not the well knowledge with turbo, then i wouldnt go turbo. </TD></TR></TABLE>
i understand everything with turbo cars, but safm, and fm and crome and that stuff, and socket ecu's, im really blurry on all that, i have searched for it, but no1 has really like explained it to me, but after that, i would have a really good concept on fi
I remember reading somewhere that the you could use the old blue boxs on newer civics, just that the wiring was different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">I remember reading somewhere that the you could use the old blue boxs on newer civics, just that the wiring was different.</TD></TR></TABLE>
I admit to not knowing every thing. I just remember comparing a Y8 uberdata map to a P28 (Z6) map. The timings were way different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">what does the bluebox do anyway???</TD></TR></TABLE>
I assume its the equivilant of Hondata/Uber/Crome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">Im running a blue box from a 92+ sohc in my 00 ex for the last 2years with no issues. Im also running a wideband o2 and everything is solid, no issues at all.</TD></TR></TABLE>
I think the fuel maps are very close, its the ignition that is differnt. I think the Y7/8 are advanced more than the Z6 engines.
You're probably running more retarded timing than necessary. (But if it works it works.
I admit to not knowing every thing. I just remember comparing a Y8 uberdata map to a P28 (Z6) map. The timings were way different.</TD></TR></TABLE>
Hmm where did they get the Y8 map from. There are only 5 maps or so on uberdata. I thought you opened the GSR map, then imported the P28 map.....then adjusted everything to your liking and save it. I am running the Z6 (P28) map on ym Y5 and the only things I adjusted were the rev limit, vtec settings and it runs good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">Hmm where did they get the Y8 map from. There are only 5 maps or so on uberdata. I thought you opened the GSR map, then imported the P28 map.....then adjusted everything to your liking and save it. I am running the Z6 (P28) map on ym Y5 and the only things I adjusted were the rev limit, vtec settings and it runs good.</TD></TR></TABLE>
A person had a map that went to 10psi, so I was going to use it as a basemap. Then I talked to him and he said it was for his Y7/8 (don't remember which). I then compared his P28 (adjusted timing for his Y) to the stock P28 map and it was very different.
dema12co
14
Dec 26, 2006 06:15 PM
