B20 or B18
Old Aug 21, 2005 | 04:57 PM
EgKrnBoy's Avatar
Default B20 or B18
I just wanted to know wat should i go wit a b20vtec or a lsvtec if i was tryin to push about 30 psi of turbo????????? but all the things i am doin im gettin dart sleeves and alot more stuff done but i jus got this eg from the junk yard so startin from stratch ppl tell me............ or wat would other motors be better
Old Aug 21, 2005 | 05:09 PM
Stoich EG2's Avatar
Default Re: B20 or B18 (EgKrnBoy)
an SR20 would pull a premium before race wars
Old Aug 21, 2005 | 05:12 PM
EG6Krew's Avatar
If you want to rev high and boost you need to run lower displacement like a B16, or even a B18. If you want to boost hell alot and just have tons of torque go with the B20B. Just be aware that if you really are going to spend the money and you might want to get golden eagle sleeves cause my friend has gone through three Darton blocks. But if this was my car I would do a Ls/Vtec so than you can revv a hella high and boost tons and 30lbs might be over kill for a street car, it depends on what you call a street car. I had a LS with 12PSI and I was beating EVOS so maybe you might just want to get a GSR or LS and turbo it. Its not how much power you have, its how well you can get it to the ground. Hope this helps a little.
Old Aug 21, 2005 | 05:25 PM
Gunmetal_B20_Hatch's Avatar
Default Re: B20 or B18 (EG6Krew)
keep in mind that most of the time B20 sleeves will give out under less stressful conditions than b18's. You WILL want to resleve the b20 block if plan on running 30 psi. that is a bit much for a street car. you should be quite happy w/ 10-15 psi from what i hear.
Old Aug 21, 2005 | 06:13 PM
hYbRiD EeEkAy's Avatar
Default Re: B20 or B18 (Gunmetal_B20_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunmetal_B20_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind that most of the time B20 sleeves will give out under less stressful conditions than b18's. You WILL want to resleve the b20 block if plan on running 30 psi. that is a bit much for a street car. you should be quite happy w/ 10-15 psi from what i hear.</TD></TR></TABLE>
if hes never driven a turbo car im sure hell be happy with less.. lol
slideintegra08
Aug 6, 2021 07:30 PM
gixxerboy750
Sep 14, 2010 10:57 AM
Tofu94
Jan 20, 2005 06:48 AM
elitesi8
Jun 27, 2004 06:40 PM
Ek9_6
Mar 6, 2003 11:39 AM
