Bad TPS?
When i'm driving the throttle will cut out completely and sometimes kick back up again if i push down the gas pedal a bit more. Usually this occurs when i'm at low throttle and I don't know if anyone else has had this problem. It came all of sudden and I'm not sure if it's a bad TPS, or fuel pump or clogged injectors.
btw...the search feature was down when i made this
You check engine light does work right, it comes on for 2 seconds when you start the car ?
Almost sounds like it could also be the 02 sensor, usually the tps will throw a code if something is wrong with it.
I would say start looking else where, if the tps was bad the ecu would let you know. But you can always take a dvom meter and test the voltage to see if everything is running smoothly with the tps, there could be a short or open in the tps and it just happens so quick that the ecu does not catch it.
