Bad TPS?
Old Aug 20, 2005 | 02:20 PM
mlsmith95gsr's Avatar
Default Bad TPS?
When i'm driving the throttle will cut out completely and sometimes kick back up again if i push down the gas pedal a bit more. Usually this occurs when i'm at low throttle and I don't know if anyone else has had this problem. It came all of sudden and I'm not sure if it's a bad TPS, or fuel pump or clogged injectors.
btw...the search feature was down when i made this
Old Aug 20, 2005 | 02:30 PM
RCautoworks's Avatar
Default Re: Bad TPS? (mlsmith95gsr)
Check engine light on ?
Old Aug 20, 2005 | 02:46 PM
Default Re: Bad TPS? (90blackcrx)
no check engine light. but the "maintenance req" light blinks when i turn on the car...i'm not sure if that means that i need to go and reset it again soon.
Old Aug 22, 2005 | 07:30 AM
lemongreenhatch's Avatar
i have the same problem i would like top know
Old Aug 22, 2005 | 07:54 AM
CNSK's Avatar
did you mess with the plug harness? the tps sensor and map sensor can both fit eachother....make sure you plug the correct one to eachother. That could be a reason
Old Aug 22, 2005 | 08:16 AM
Default Re: Bad TPS? (CNSK)
they are correct
Old Aug 22, 2005 | 09:16 AM
Default Re: Bad TPS? (poorman's-allmotor)
You check engine light does work right, it comes on for 2 seconds when you start the car ?
Almost sounds like it could also be the 02 sensor, usually the tps will throw a code if something is wrong with it.
Old Aug 22, 2005 | 09:31 AM
yea engine light works
Old Aug 22, 2005 | 10:15 AM
I would say start looking else where, if the tps was bad the ecu would let you know. But you can always take a dvom meter and test the voltage to see if everything is running smoothly with the tps, there could be a short or open in the tps and it just happens so quick that the ecu does not catch it.
mcnos
Dec 18, 2011 11:53 AM
realmike15
Honda Civic (2001 - 2005)
Nov 12, 2010 09:38 AM
dc2integtypR
Oct 5, 2005 11:02 PM
AMG
May 25, 2005 12:18 PM
RedHackBatch
May 5, 2003 08:44 PM
