LS-Vtec Turbo compression question
Old Aug 19, 2005 | 03:43 PM
jdmcivic1999's Avatar
Default LS-Vtec Turbo compression question
ok i just picked up my t3/t4 turbo kit and now i found a good deal on a fully built b18b bottom end. its bored and sleeved to 85mm with ross pistons and eagle rods. the compression is 11:8:1 i believe. im gonna turbo the motor but do you guys think that this compression ratio is too high for a turbo. should i go out and get some lower compression pistons like 9:5:1 or 8:5:1? let me know what you guys think. the head im gonna use will probably be the fully built b16 i have for LS-Vtec.
Old Aug 19, 2005 | 05:48 PM
beerbongskickass's Avatar
Default Re: LS-Vtec Turbo compression question (jdmcivic1999)
If this car is going to be mostly run on pump gas then your going to want around 9:1 compression. I would get a different block that isn't bored out as much too.
Old Aug 19, 2005 | 06:35 PM
Si Shane's Avatar
Default Re: LS-Vtec Turbo compression question (beerbongskickass)
with a solid tune you should be detonation free at 7-10psi depending, but with the addition of a water injection system you could make more power, safer. The 85mm bore should be fine. if the motor is out of the car just get some new pistons with a nice flat top and all will be ****.
ChrisYuki
Aug 16, 2015 08:19 PM
civic-r11
Mar 31, 2009 12:04 PM
CRXherbie91
May 25, 2008 08:23 AM
LSEGHATCH
Oct 6, 2004 07:44 PM
dtec
Aug 23, 2003 02:26 PM
