Limp mode after taking out ecu
Old Aug 18, 2005 | 12:52 PM
impact_blu's Avatar
Default Limp mode after taking out ecu
Any idea why my car is running on limp mode? My car is running on a p28 and it runs fine before I took the ECU out last night. I plugged the ecu in this morning and the check engine light is on. The engine idles at 1500rpm at normal driving temperature. Is it possible that I have a bad ecu? I haven't had time to check any cel codes since I'm still at work. Any thoughts or input on this?
Old Aug 18, 2005 | 01:36 PM
IHateJDM's Avatar
Default Re: Limp mode after taking out ecu (impact_blu)
what makes you think that you are in limp mode? your idle will be off at first until the ecu re-learns the engine. If you have cels, get the codes before you start worrying about a bad ecu.
bk7794
May 29, 2012 09:32 AM
drumminforev
19
Oct 6, 2006 12:12 AM
b16ahybrid
Feb 13, 2006 02:44 PM
ludatic
Nov 2, 2003 10:46 PM
TurboRedSi
Jul 17, 2003 10:59 PM
