B16 with LS crank
Im building the 1.9L B16 with a LS crank, I need some info an advise. Im looking to put forged rods an pistons in it. Would boring it to 84mm over be alright. Im just new with this hybrid so i need some help. help me out.
http://www.inlinefour.com
http://www.passowrdjdm.com
the bore size your wanting shouldnt affect anything but you will need to prob special order the pistons, due to the fact that a ls crank has a longer stroke and depending on the rods you use, the deck clearance could be a issue.
yea i know about the custom pistons, im looking at gettin either crower or pauter rods. I know aries sells the custom pistons for this setup. Im still researching it all. But im greatful for all the advice I can get.
what more do you need? did you also see this link as well?
https://honda-tech.com/zerothread?id=815614&page=1
Check out this thread:
https://honda-tech.com/zerothread?id=1333349
It allows you to run proper length rods with the LS crank.
