Timing EMERGENCY
Old Aug 17, 2005 | 03:47 PM
sik civic's Avatar
Default Timing EMERGENCY Fixed not replies neccessary!!!
Just finished putting ne cams and valve train in my JDM B16A and I for some reason turned the crank pulley taking it off of the TDC position it was in before I removed the timing belt.
I can't get the crank pulley off so I can then get the dust cover off the bottom end to see the mark on the block and crank so I can align the two, How do I sort this problem out?
Modified by sik civic at 5:17 PM 8/17/2005
Old Aug 17, 2005 | 05:07 PM
sickerhatch's Avatar
Default Re: Timing EMERGENCY Fixed not replies neccessary!!! (sik civic)
just line up the mark on the timeing belt cover to the one one the crank pully.Its the same mark that you would use to set the timeing with a timeing light.
Old Aug 17, 2005 | 07:58 PM
drdisco69's Avatar
Default Re: Timing EMERGENCY Fixed not replies neccessary!!! (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote">just line up the mark on the timeing belt cover</TD></TR></TABLE>
thesmogman
Sep 15, 2006 08:05 PM
impr323
Sep 25, 2005 09:05 AM
Gump
Jun 2, 2004 05:01 PM
WannaHonda
May 6, 2004 10:12 AM
