ITR, LS/VTEC
Old Aug 17, 2005 | 01:56 PM
b18ctrb's Avatar
Default ITR, LS/VTEC
I was wondering if the JDM ITR pistons and rods will work in a B18A1 block, or do I have to use the LS rods ???
Old Aug 19, 2005 | 02:51 AM
efstile's Avatar
Default Re: ITR, LS/VTEC (Deni)
yuo would have to use the crank out of the type r motor. not the best idea though. sell the type r **** and get a hot set of aftermarket rods and pistons. little more money but probabbly the easier route. finding a type r crank would be a bitch if you dont have one. and the ls crank makes for a little more displacement than the type r because of the longer stroke. so like i said. sell the type r stuff and get some nice aftermaket ls rods. the pistons arent a bad choice though. depends on what kinda motor you are building. ideal for a daily driver or even a well built turbo motor. its a good bit of compression. but if you are going all motor and haave some cams i would opt for some aftermarket peices like 11.5:1 and make sure you order them for an ls
Old Aug 19, 2005 | 11:20 AM
slayersluck's Avatar
i don't think type R rods would go wid the LS crank... I think one of my friends tried it and his motor blew up... LS RODS for a fact
Old Aug 19, 2005 | 11:25 AM
b18ctrb's Avatar
So I would have to use my LS rods with my Type R pistons. I would also be able to use my LS crank then correct ? I am just building a little all motor set up for my winter car, so it will be a daily driver. I dont want to spend all kinds of crazy money for a winter car
Old Aug 19, 2005 | 05:26 PM
Combustion Contraption's Avatar
You need to do ALOT Of searching before you begine this setup. Different combos of rods/cranks will yeild different piston to deck height and could cause catastrophic engine failure. Such as LS crank with Type R rods.....
Old Aug 20, 2005 | 08:15 AM
b18ctrb's Avatar
Would it be easier if I would just use LS rods with the ITR pistons then ?
Old Aug 20, 2005 | 02:54 PM
91civicDXdude's Avatar
use the matching rods for your crank, and it doesnt matter what piston you use... all b16/b18 pistons will work.
Old Aug 20, 2005 | 08:43 PM
Default Re: (Deni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deni &raquo;</TD></TR><TR><TD CLASS="quote">So I would have to use my LS rods with my Type R pistons. I would also be able to use my LS crank then correct ? I am just building a little all motor set up for my winter car, so it will be a daily driver. I dont want to spend all kinds of crazy money for a winter car</TD></TR></TABLE>
yes...LS RODS with type r pistons
Old Aug 21, 2005 | 08:46 AM
b18ctrb's Avatar
Will the LS rods be strong enough ?
Old Aug 22, 2005 | 01:22 PM
B18aHatch's Avatar
a stock ls bottom end i have seen handle 14psi of boost on a well tuned motor. LS rods are gona be plenty stong enough for what ur doing.
Old Aug 22, 2005 | 05:15 PM
Default Re: (B18aHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18aHatch &raquo;</TD></TR><TR><TD CLASS="quote">a stock ls bottom end i have seen handle 14psi of boost on a well tuned motor. LS rods are gona be plenty stong enough for what ur doing.</TD></TR></TABLE>
just get some ARP rod bolts and ur good to go
Old Aug 23, 2005 | 01:32 AM
mdixonjam's Avatar
Default Re: (slayersluck)
Like the guys said, keep your LS crank, use the LS Rods with some ARP Rod Bolts (the Rod Bolts are the weak link) and your choice of pistons according to the Compression Ratio you are trying to achieve.
Using the Type R pistons will give you a nice LS/VTEC daily driver.
I didn't get what head you were using though ?? B16A, B18C1 or B18C5 ???
It would be nice and safe to use upgraded valve trains like in the Type R head (not absolutely necessary for your setup).
Old Aug 25, 2005 | 11:50 PM
b18ctrb's Avatar
Well I ma using a B16 PR-3 head. So basically all I have to get is some new rod bolts and this will be a dependable daily driver LS/VTEC ?
Old Sep 1, 2005 | 07:31 AM
mdixonjam's Avatar
Default Re: (Deni)
You should be quite fine with what you have and upgrading the Rod Bolts.
Definitely a dependable daily driver.
turbodcxbro
25
Jan 7, 2010 07:30 AM
TurboEH2
Apr 2, 2005 11:15 AM
takumi604
Mar 21, 2005 03:33 PM
slodel
Jun 18, 2004 12:14 AM
allmtrdc4
Jun 3, 2004 04:05 PM
