JDM Type R swap question
Old Feb 23, 2002 | 12:19 AM
jdmciviceg's Avatar
New User
Default JDM Type R swap question
Hey guys,
I ordered a JDM Type R complete swap and was just thinking. Are the axle splines the same as my hatch? I didn't know if they would work or not knowing the lug pattern was different....is the spline different too? Is there anything else that might not work besides the obvious? I'm converting it to OBD1 so I already know all of the stuff that I needed for it. Any input would be appreciated.
Old Feb 23, 2002 | 12:21 AM
Kamin's Avatar
Default Re: JDM Type R swap question (jdmciviceg)
the axles sould work fine.
Old Feb 23, 2002 | 08:50 PM
2001silvergsr's Avatar
JDM axles have a larger hub size than usdm axles. might have a problem with that.
Old Feb 24, 2002 | 05:45 PM
jdmciviceg's Avatar
New User
Default Re: JDM Type R swap question (2001silvergsr)
ok..now I have two different answers. Who on this board has personal experience with what I am talking about? Will they work or do I need to get other axles...and if they are a larger hub diameter, is the transmission side of the drive shafts larger also? If that is the case, then what in the hell will work? Please advise.
Old Feb 24, 2002 | 06:08 PM
GokuSSJ4's Avatar
b18c in a hatch with no problems , no need to mod !
Old Feb 24, 2002 | 06:45 PM
Kamin's Avatar
Default Re: JDM Type R swap question (Spoon1)
just because its a jdm motor dosent mean your getting jdm axles
ask the place where you ordered the swap
99% chance they are not sending you jdm axles...
Old Feb 25, 2002 | 05:58 PM
jdmciviceg's Avatar
New User
Default Re: JDM Type R swap question (KAMiN)
Thats a good point. I'll give him a call and find out. Thanks.
Old Feb 25, 2002 | 08:12 PM
blykins's Avatar
Banned
Japan usually just cuts the axles off.
Old Feb 25, 2002 | 08:19 PM
MurphDog74's Avatar
so if the axles come off the jdm engine they arent gonna fit into the usdm hubs? Doin a b16 into a 95 civic lx
JulioRX
Aug 24, 2008 10:44 PM
EGB18
Jul 12, 2004 07:49 AM
Project99EK
Mar 13, 2004 09:04 AM
2001silvergsr
Feb 10, 2002 05:26 PM
