Tachometer and Speedometer
Old Aug 16, 2005 | 08:50 PM
themorphious's Avatar
Default Tachometer and Speedometer
OK, I have owned a 1994 EX civic 2 door for about a week now. When The RPM's get high, about 4 grand or so, the speedometer goes nuts. It jumps to like 100 mph and then drops andthen stays at zero for a while then returns to normal. Then for the tachometer; The engine does some sort of fuel cut at the end of 1st gear, about 38 mph. Now the catch is, it reads that the engine is at about 5500 RPMS. I believe that it should be saying something like 7200, but it's not. I am sure it is a d16z6, so it is the SOHC vtec and is revving that high, but the tach is wrong....HELP!!! WHAT is wrong with these gauges?
Modified by themorphious at 6:21 PM 8/18/2005
Old Aug 16, 2005 | 09:29 PM
Default Re: Tachometer and Speedometer
Come on people, what's tha answer?
Old Aug 18, 2005 | 08:26 AM
no one knows how to solve this problem?
Old Aug 18, 2005 | 09:33 AM
JimBlake's Avatar
Default Re: Tachometer and Speedometer (themorphious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious &raquo;</TD></TR><TR><TD CLASS="quote">OK, I have owned a EX civic 2 door for about a week now...</TD></TR></TABLE>Have you owned it long enough to know what model-year it is? Not likely I'll know the answer to your question, but Honda used 2 or 3 different ways to drive the speedo & tach over the years.
Old Aug 18, 2005 | 05:19 PM
Old Aug 19, 2005 | 08:37 AM
JimBlake's Avatar
Default Re: (themorphious)
I'm pretty sure the tachometer signal is a blue wire from the distributor back to the dash. Look for loose/dirty/corroded connections.
Maybe it still had a speedometer cable in '94 (not sure)? Otherwise there's a VSS on the tranny where you can check for screwed up wiring.
Groove_D
32
Dec 22, 2018 11:35 AM
epak
16
Oct 7, 2006 04:37 PM
90b20b4
12
Aug 14, 2005 10:18 AM
Jaydeep
19
Aug 21, 2003 11:09 AM
LazYRaCeR
Jun 22, 2003 12:08 PM
