camera mount strap?
my friend made a headrest camera mount and it works pritty well. he's gonna use it for autocrosses this season, but it needs a safty strap. does anyone know the specs on the strap? what does it have to attach to? is there a spec. size for the strap?
You are basicaly looking at keeping the camera from flying around and hitting your self or passenger if you have a oooops.A simple strap with buckle type lock same as your helmet.
Most camera mounts come with these.As far as i know there is no actual specs on this type of thing.Just make sure it will not come loose and hit your head.
[Modified by typealex2, 5:32 AM 2/23/2002]
I just made a camera mount exactly like that. It also bolts to the headrest.
here is a link to some pics:
http://www.imagestation.com/album/pi...?id=4292035717
later,
aj
later,
aj
later,
aj
later,
aj
As for the strap, try a large dog collar. They're VERY strong, and have a nice plastic clip.
How come you put it on the driver's seat? Seems like an added danger that could easily be avoided by mounting it on the passenger's seat.
I will be swapping it to the other side asap.
thanks,
aj
why is it an added danger to have it on the driver's seat? If the camera's loose... does it matter what side it was originally anchored to?
As you mentioned, if the camera comes loose on it's own, it doesn't really matter, but if the camera is knocked loose, that setup could send it toward the driver.
Ironically, or perhaps not, a camera strap as mentioned in the first post would greatly add to the safety of either setup
Slo_RSX
Dec 7, 2008 04:18 AM
