Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
camera mount strap?
Old Feb 22, 2002 | 09:05 PM
Lo-Buck EF's Avatar
Default camera mount strap?
my friend made a headrest camera mount and it works pritty well. he's gonna use it for autocrosses this season, but it needs a safty strap. does anyone know the specs on the strap? what does it have to attach to? is there a spec. size for the strap?
Old Feb 23, 2002 | 04:27 AM
typealex2's Avatar
Default Re: camera mount strap? (SOLOef)
You are basicaly looking at keeping the camera from flying around and hitting your self or passenger if you have a oooops.A simple strap with buckle type lock same as your helmet.
Most camera mounts come with these.As far as i know there is no actual specs on this type of thing.Just make sure it will not come loose and hit your head.
[Modified by typealex2, 5:32 AM 2/23/2002]
Old Feb 23, 2002 | 12:38 PM
Aahj's Avatar
I just made a camera mount exactly like that. It also bolts to the headrest.
here is a link to some pics:
http://www.imagestation.com/album/pi...?id=4292035717
later,
aj
Old Feb 23, 2002 | 04:57 PM
travis's Avatar
Default Re: camera mount strap? (ajn)
later,
aj
How come you put it on the driver's seat? Seems like an added danger that could easily be avoided by mounting it on the passenger's seat.
As for the strap, try a large dog collar. They're VERY strong, and have a nice plastic clip.
Old Feb 23, 2002 | 08:39 PM
Aahj's Avatar
Default Re: camera mount strap? (ITR#231)
good idea,
I will be swapping it to the other side asap.
thanks,
aj
Old Feb 23, 2002 | 08:59 PM
WRXRacer111's Avatar
why is it an added danger to have it on the driver's seat? If the camera's loose... does it matter what side it was originally anchored to?
Old Feb 23, 2002 | 09:20 PM
travis's Avatar
Default Re: camera mount strap? (WRXRacer111)
I'm not sure that it really is any worse. Still, it would seem that having that bar behind your head and pointed in your direction if it were to come loose or break would be easily avoided. In a frontal impact, the camera will accelerate on an arch toward the driver's side, with the fulcrum of the arch just behind the driver's right ear. If mounted to the passenger's seat, that arch is directed away from the driver. Again, this is worse case, but an easy fix.
As you mentioned, if the camera comes loose on it's own, it doesn't really matter, but if the camera is knocked loose, that setup could send it toward the driver.
Ironically, or perhaps not, a camera strap as mentioned in the first post would greatly add to the safety of either setup
Old Feb 24, 2002 | 04:19 PM
92cxgsr's Avatar
Does anyone know how to mount or where to mount a camera into a 92-95 civic with the single post head rests??????/
Old Feb 24, 2002 | 04:36 PM
Lo-Buck EF's Avatar
Default Re: camera mount strap? (92cxgsr)
get a harness bar
Old Feb 24, 2002 | 05:20 PM
mozart's Avatar
get a harness bar
I second that!
Having sharp metal objects pointing towards your neck is not a comforting feeling
Old Feb 24, 2002 | 06:07 PM
Default Re: camera mount strap? (mozart)
Or you could use PVC pipe that extends all the way across between both seats.
turboHondaWesJ
Welding / Fabrication
Jan 7, 2013 02:59 AM
turboHondaWesJ
Jan 5, 2013 01:49 PM
GsRrrr
Jan 5, 2011 10:27 PM
jnguyen27
Aug 17, 2009 07:57 PM
Slo_RSX
Dec 7, 2008 04:18 AM
