A/C question. Please help!
Old Aug 16, 2005 | 09:45 AM
hbhonda's Avatar
Default A/C question. Please help!
Does anyone know why my a/c blows cold when I'm driving on the highway but not when I'm driving in town in stop and go traffic? Also, is there anyway to correct it? Input is greatly appreciated!
Old Aug 16, 2005 | 09:49 AM
b18ccivics's Avatar
Default Re: A/C question. Please help! (hbhonda)
make sure your ac fan is coming on. if it is then take it to a shop and see if i is not low on r-134 if it is then up grade the fan to a more cfm one, honda doesnt know how to make a good fan.
Old Aug 16, 2005 | 10:17 AM
Cuong-nutz's Avatar
You could have a leak in your ac system. Go get your system tested. You could just add some more refrigerant if it is low and see if it that helps.
92-93=R12 (unless it was converted)
94-95=R134a
Old Aug 16, 2005 | 10:23 AM
ApolloSpeed's Avatar
Default Re: A/C question. Please help! (Cuong-nutz)
I wish mine blew less CFM.....my 94 Del Slow on the Low setting.....blows like a 500 dollar blow job !!!
Old Aug 16, 2005 | 11:01 AM
dwnthehatch's Avatar
Default Re: A/C question. Please help! (ApolloSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I wish mine blew less CFM.....my 94 Del Slow on the Low setting.....blows like a 500 dollar blow job !!! </TD></TR></TABLE>
I know what you mean. I just bought one of the $20 recharge kits and recharged my del sol. It's freezing inside with the top on.
Old Aug 16, 2005 | 07:58 PM
hbhonda's Avatar
Default Re: A/C question. Please help! (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">make sure your ac fan is coming on. if it is then take it to a shop and see if i is not low on r-134 if it is then up grade the fan to a more cfm one, honda doesnt know how to make a good fan.</TD></TR></TABLE>
would the dryer have anything to do with it?
Old Aug 16, 2005 | 08:00 PM
hbhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">You could have a leak in your ac system. Go get your system tested. You could just add some more refrigerant if it is low and see if it that helps.
94-95=R134a
i jsut had custom a/c lines made and it vaccumed and charged no more than 2 weeks ago.
Old Aug 16, 2005 | 08:14 PM
95DxSi-R2
Guest
Posts: n/a
custom lines? however made your custom lines is very smart or really fu#kin dumb
ok, either you have a leak......your low on freon.......or you have some build up (bugs n stuff) on your condenssor, or the fins on the condessor are closed (there has to be alot of them)
if your fans weren't coming on, the comp. blow off valve would let it out or u would have a massive leak. those are the only reasons i can think of
Old Aug 16, 2005 | 08:15 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: A/C question. Please help! (95DxSi-R2)
who vaccumed and charged it?
Old Aug 16, 2005 | 09:00 PM
Falqon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">ok, either you have a leak......your low on freon.......or you have some build up (bugs n stuff) on your condenssor, or the fins on the condessor are closed (there has to be alot of them)</TD></TR></TABLE>
Ok, lets think about this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbhonda &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know why my a/c blows cold when I'm driving on the highway but not when I'm driving in town in stop and go traffic? Also, is there anyway to correct it? Input is greatly appreciated!</TD></TR></TABLE>
If it blows cold on the highway, then he does NOT have a leak, and is NOT low on freon and I highly doubt he has bugs in his condensor fins. Check your fan, probably isn't coming on like it should.
Nicholas Bailey
May 15, 2016 07:56 AM
blackj30_a
Jun 23, 2015 05:40 PM
si_motor_spt
Sep 29, 2012 09:00 PM
ATrin
Jun 28, 2008 12:33 AM
Totalpkg
Jun 10, 2005 10:51 AM
