bitch pin*****
Old Aug 15, 2005 | 03:33 PM
5thgencivicr's Avatar
Default bitch pin*****
i went to get the shift linkage for my 5 speed swap today....i had to twist and break off one of the linkages becuase of that pin....how the **** do u remove it? damn.
Old Aug 15, 2005 | 03:35 PM
SirRevvs's Avatar
Default Re: bitch pin***** (5thgencivicr)
Son that's why they call it the bitch pin . You need the correct size center punch, a hammer, and a little elbow grease
Old Aug 15, 2005 | 03:37 PM
JDM-97CX's Avatar
Default Re: bitch pin***** (SirRevvs)
I used a sawzall on mine because I wasn't reusing the linkage but an air hammer with a taper punch bit works great.
so it does just punh out? it doesnt matter from wich end i do this? and also i plan on buying a new one. does it have to be pressed in...or can i just hammer in the new one? thanks....and yes the name "bitch" is an understatment.
Old Aug 15, 2005 | 03:39 PM
you know were it has 2 10mm bolts were the shifter end bolts up to the underside of the car? are the threads there for those 2 10mm bolts on my auto? or do i have to drill and tap? i have almost everything for my swap except the 5 speed starter and brake pedal......then im on my way.
Old Aug 15, 2005 | 03:42 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">so it does just punh out? it doesnt matter from wich end i do this? and also i plan on buying a new one. does it have to be pressed in...or can i just hammer in the new one? thanks....and yes the name "bitch" is an understatment.</TD></TR></TABLE>
Yes punch it out from either end, and when reinstalling just hammer it back in. I'm to the point now where I just leave the linikage on the tranny if I drop it for some reason. IMO its easier to take off a couple of exhaust hangers.
Old Aug 15, 2005 | 03:43 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">you know were it has 2 10mm bolts were the shifter end bolts up to the underside of the car? are the threads there for those 2 10mm bolts on my auto? or do i have to drill and tap? i have almost everything for my swap except the 5 speed starter and brake pedal......then im on my way. </TD></TR></TABLE>
Not sure if they're there or not, check underneath your car :shrugs: but they're 12 mm's not 10's
Old Aug 15, 2005 | 03:45 PM
yea i ment 12....i was thinking 10 becuase of the brakec pedal...anyway thanks for the help guys. i hope this swap gos off with little problems. i have red up on it so much and have been collecting the swap parts over a period of 5 months. i got a tranny from a dx with 70k miles...(hope a dx tranny is fine) i have a 93 ex coupe with d16z6.
Old Aug 15, 2005 | 03:52 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">yea i ment 12....i was thinking 10 becuase of the brakec pedal...anyway thanks for the help guys. i hope this swap gos off with little problems. i have red up on it so much and have been collecting the swap parts over a period of 5 months. i got a tranny from a dx with 70k miles...(hope a dx tranny is fine) i have a 93 ex coupe with d16z6. </TD></TR></TABLE>
This is the best place to find information on Honda swap oriented stuff. Keep searching the archives there is alot of very useful info in there. DX tranny will work fine but I believe the gears are a little longer than the EX. Anyway good luck with the conversion
Old Aug 15, 2005 | 03:56 PM
thanks man....yea i have red everything in here about the swap and bookmarked it all.....lol. damn i didnt know the dx tranny gears were longer....that sucks. i may start searching for a ex or si tranny now. thanks for the info.
Old Aug 16, 2005 | 01:33 AM
kkim's Avatar
http://forums.hondashowoff.com...&st=0&
Old Aug 16, 2005 | 04:21 AM
fOmaNPu's Avatar
i just dragged mine out with the motor and worried about it later =D
jdm-style-dc2
Mar 12, 2011 07:29 AM
ragnarok0mega
Jun 4, 2009 04:14 AM
verbal assassins
Feb 16, 2007 03:59 PM
92CIVICCX
Jan 20, 2003 11:10 AM
Wazup
Nov 22, 2002 11:57 PM
