Idle is messing up
Old Aug 15, 2005 | 07:41 AM
B bOy CrAyOn's Avatar
Default Idle is messing up
I own a 93 EG wit a jdm b16 and ur basic bolt ons and a lil more but no internal work..... its alway drove fine and given me no problems but about 2 weeks ago the idle keeps fluctuating when i stop at a light or any time im idling... it will idle fine till the car warms up...once the engine is warmed up and should be running great it will idle at 700 or 500 or 1,000 or 100 .... and itll change through all these idle positions within maybe a 3 block radius of stop and go traffic... and if im driving around 50 or higher or any speed actually and i put it in neutral and coast to a stop somtimes it will totally just turn off and i have to turn the car on again... cuzz the car seems to idle at 100 a lot now... wich in my perspective i thought the car should turn off at that low of a rpm.... anyone know what it could be?
Old Aug 15, 2005 | 10:39 AM
zman's Avatar
Default Re: Idle is messing up (B bOy CrAyOn)
idle air control valve on the back of the intake manifold....very common problem. Take it off and clean the screen, if that doesn't work get a new one, or a used one that works....they aren't cheap from honda.
Old Aug 15, 2005 | 11:05 AM
i have a skunk2 intake manifold so would it be any different?..prolly not... just for a lil more help what does the idle control valve look like and how do i take it off?
Old Aug 15, 2005 | 11:13 AM
nvm i think i found it....it has some hoses that go in to it ad a sensor i think and bolted up by 2 bolts... so ill take it off and clean it
Old Aug 15, 2005 | 12:08 PM
ok i cleaned it and it was super clean and all..i took my car for a ride... and its still doing the same thing....what else could it be?
Old Aug 15, 2005 | 12:38 PM
zman's Avatar
Default Re: (B bOy CrAyOn)
well cleaning it doesn't always fix the problem. Try replacing it with a known working one....lots of other honda ones fit, there is one with wide bolt holes and there is one with closer bolt holes, and some have 2 wires and others have 3. I am currently using a 91 integra IACV on my 2nd gen b16.
Old Aug 20, 2005 | 03:31 AM
i_kick_turtles's Avatar
Default Re: (zman)
make sure to check for any leaky or cracked hoses. also take the radiator cap off and let the car idle for a long time.
Old Aug 21, 2005 | 09:48 AM
jdm420da6's Avatar
Default Re: (I R Tylor)
im having troubles with idling myself...it idles way too high, like 16-2100 rpms...at a light...talk about killer fuel economy...anyway...u think leaving the rad. cap off for awhile will help any?
Old Aug 21, 2005 | 09:34 PM
Default Re: (jdm420da6)
if it fluctuates its sometimes just air in the cooling system. you can bleed it with the screw or just idle with the cap off. if it's just going to high its probably something else. have you worked on the throttlebody recently?
Old Aug 22, 2005 | 04:18 PM
jdm420da6's Avatar
i noticed that when i push on the throttle plate some it goes down..but not enough...i even tried cleaning it and it doesnt help...i dunno what else to check for
VTECwalka
Nov 4, 2012 06:58 PM
B bOy CrAyOn
Aug 15, 2005 02:01 PM
raene
Nov 7, 2002 08:21 PM
