Alternator Test machines...
I just got my rebuilt Autozone Alternator tested at Checker auto parts, and it came out to be within they're limits, and passed all three tests.
However, when it was installed in my car, it was reading about 17Vs at idle and would increase when I reved the car.
Do these test machines test the voltage regulator, or if it just puts out a charge at all?
TIA,
Bryson
TIA,
Bryson
The machines do check the voltage regulator its usually a sweep dial and is very hard to miss if its not within spec.
Hmm, I would have it checked somewhere else.
Either.
1.) They didnt use the correct test chart.
2.) They were not paying attention to the test lights, espicaly the one that tells you if the regultor is "hanging up"(?)
Im still new at using these machines so best bet would be to take it to Another auto parts store have them test it and explain to them your problem.
Either.
well I took it back to the autozone that I bought it at, and they also checked it. However, this time it failed so I guess they were trying to test the wrong alternator.
I got an OEM Honda nippon denso and the cars running great.
Outlaw-Hondaz
Nov 22, 2010 06:20 PM
alternador, alternator, alternators, altornetar, autozone, chart, dial, failed, machine, machines, passed, test, tester, text
