question about exhaust size?
Old Aug 14, 2005 | 04:22 PM
blk007's Avatar
Default question about exhaust size?
i'm gonna be putting a b16 into my eg..it has like close to 2 inch piping right now. I've researched and learnt that too big of a piping wouldn't create enough back pressure and thus you'll have a lose of power. 2.25" should be enough but this is where i get confused, i also learnt that you should install the piping with future modding in mind like if you might need 2.5" later on, i plan on doing b20 vtec bottom end...but first i'm gonna install the b16 and do head work...then bottom end. What size piping should i get installed? would 2.25" be sufficient for a b20 vtec car built for the street and some track use? also is there a disadvantage to using a muffler with a 2.25" inlet if u're running 2.5" piping? just wanted to know before i bought a specific muffler.Thanks in advance guys
Old Aug 14, 2005 | 04:56 PM
SpdFrk's Avatar
Default Re: question about exhaust size? (blk007)
If your planning to build the engine in the future go with 2.5".
Old Aug 14, 2005 | 07:17 PM
drdisco69's Avatar
Why would you want backpressure?
Old Aug 15, 2005 | 08:27 AM
blk007's Avatar
Default Re: question about exhaust size? (drdisco69)
Read this thread and you'll see http://www.torontocivics.com/t...+size<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want backpressure? </TD></TR></TABLE>
Old Aug 15, 2005 | 08:33 AM
drdisco69's Avatar
No, I think YOU need to read that thread...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that thread you posted &raquo;</TD></TR><TR><TD CLASS="quote">Urban Myth: "Hondas need backpressure" ... You need the combination of the least positive (close to zero) backpressure possible with the highest gas velocity achievable to create performance
Do not confuse backpressure with velocity.
Old Aug 15, 2005 | 01:29 PM
BoOstedEM1's Avatar
IF you open the pipes up to much you lose velocity of the exhaust....thus loosing torque..but gaining a little horsepower..Now if you dont open enuf you loose horsepower but keep or drop some torque..I think you should go with the 2.5 its good all around..till you go turbo...
Old Aug 15, 2005 | 04:59 PM
blk007's Avatar
Default Re: question about exhaust size? (BoOstedEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">IF you open the pipes up to much you lose velocity of the exhaust....thus loosing torque..but gaining a little horsepower..Now if you dont open enuf you loose horsepower but keep or drop some torque..I think you should go with the 2.5 its good all around..till you go turbo...</TD></TR></TABLE>
i think that's exactly what i'll do.i was worried i would have a problem with the b16 with 2.5" piping but if it's gonna be fine, then i might as well do it to 2.5 .
Old Aug 15, 2005 | 05:01 PM
blk007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">No, I think YOU need to read that thread...
Do not confuse backpressure with velocity. </TD></TR></TABLE>
so in other words 2.5" would be better for velocity since backpressure is a myth?
Old Aug 15, 2005 | 05:14 PM
drdisco69's Avatar
I have 2.5" with a B18C, I don't see any problem with low end torque. I can get everywhere I need to through traffic shifting under 2,500rpm.
Old Aug 15, 2005 | 05:38 PM
blk007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I have 2.5" with a B18C, I don't see any problem with low end torque. I can get everywhere I need to through traffic shifting under 2,500rpm. </TD></TR></TABLE>
thanks man...i guess i could put that myth about backpressure to rest now.
Old Aug 15, 2005 | 05:49 PM
drdisco69's Avatar
One down, thousands to go...
Old Aug 15, 2005 | 06:32 PM
d16dcoe45's Avatar
Yeah, explain why if you gain velocity through a large exhaust, you lose torque. You put it into terms like it should be obvious. I don't buy that you need a certain amount of backpressure or you lose "torque"
civic_jason
75
Dec 7, 2012 01:09 PM
TypeRMOBBiN209
Other Make Vehicles
Oct 8, 2010 04:13 PM
boostedb20ek
Sep 26, 2009 12:15 AM
mistik_DC4
Nov 6, 2008 08:03 AM
91crxturbo
May 13, 2007 06:32 PM
