Swapped ECU's... now Check Engine Light is on
Old Aug 14, 2005 | 02:57 PM
numotive's Avatar
Default Swapped ECU's... now Check Engine Light is on
I drive a '99 Gs-R and about 30k miles ago, I swapped ECU's and put in a chip someone gave to me. They said it was J-Spec chip and that it would modfiy the air fuel ratios and give me more power. All I know about the chip is it was OBD-I because I needed a wire harness to convert from my OBD-II wiring. I recently decided to throw my stock OBD-II chip back in because I think the modified chip wasn't tuned properly for my setup.
Now a few hundred miles after I put the stock chip back in the Check Engine light has come on. Any ideas why this could have happened? I remember when I put the modified chip in a while back, the guy told me my check engine light might come on and that it wasn't a big deal, had something to do with swapping the chips. Is it common for the check engine light to come in after swapping chips and such? Thanks...
Old Aug 14, 2005 | 03:19 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Swapped ECU's... now Check Engine Light is on (numotive)
You need to pull the CEL (check engine light) code. It will tell you why the light is displayed.
Old Aug 14, 2005 | 03:31 PM
numotive's Avatar
Excuse my newby-ness but is there any easy way for me to do that? Is there a reasonably priced tool that will alow me to extract the error code from the chip, or should I just go to a shop and have them do it for me? It would be nice to be able to do it myself in the future, but if its not worth the price I'll just go to a shop. THanks...
Old Aug 14, 2005 | 06:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (numotive)
Welcome to H-T. Try this link:
http://www.team-integra.net/se...ID=34
delboydavies
Honda CR-V & Element
Sep 9, 2014 08:55 AM
aspire
Jun 28, 2010 10:49 AM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
93gsrhatchbrid
11
Mar 31, 2006 03:26 PM
VTECVillain
Jan 6, 2002 11:40 AM
