Help Vtec Sputters
Old Aug 13, 2005 | 08:21 PM
quicky_hatch12's Avatar
Default Help Vtec Sputters
Yea I just got my engine installed and I know that I have a bad tp sensor because it idles up and down. When the vtec was connect I noticed that when I slowly went into vtec it sounds kind of weak like it's lagging. When I'm guning it I noticed that the vtec kind of sputters, like it's turning on and off. I was told that It's because of my spark plugs and the spark plug wires. HELP!!!
Old Aug 13, 2005 | 08:48 PM
Default Re: Help Vtec Sputters (TurboLiLcIvIc605)
bump for help
Old Aug 13, 2005 | 09:23 PM
bump
Old Aug 13, 2005 | 10:26 PM
New2528's Avatar
I have the same problem about a month ago. Mine was from the VTEC oil pressure switch. I used Crome rom editer to disable the OPS, now run fine. Try that
Old Aug 14, 2005 | 08:28 AM
ok ill try
Old Aug 14, 2005 | 10:35 AM
Bump anymore suggestions
Old Aug 14, 2005 | 10:40 AM
OMG B16's Avatar
Oil pressure?
Old Aug 14, 2005 | 11:16 AM
damnraz's Avatar
you changed your oil and oil filter?, I'm assuming if you're not throwing any codes that would be the problem to the vtec oil pressure switch turning on and off, happened to me so it's worth a try
Old Aug 19, 2005 | 07:38 PM
Default Re: Help Vtec Sputters (damnraz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz &raquo;</TD></TR><TR><TD CLASS="quote">you changed your oil and oil filter?, I'm assuming if you're not throwing any codes that would be the problem to the vtec oil pressure switch turning on and off, happened to me so it's worth a try </TD></TR></TABLE>
Yea I don't have any codes and the vtec sputters when im going both slow or fast. The oil was change less than a both ago, so I don't know if that's it but Ill change it anyway. It didn't start sputtering until I ran it hard one night. Now it lags like crazy and I hear it popping like crazy.
Old Aug 19, 2005 | 08:09 PM
Anyone know? I just chanded my spark plugs/wires and the distributor rotor still know luck. I don't think it's the oil because the oil level is good.
Old Aug 19, 2005 | 09:01 PM
damn no help
Old Aug 19, 2005 | 09:40 PM
Bump better luck 2morrow
Old Aug 20, 2005 | 08:47 AM
Problem solved bad distributor coil. It was ruin because I had a cut in my old spark plug wires and it was grounding with the valve cover.
Old Aug 20, 2005 | 07:55 PM
JustinG60's Avatar
This a just a thought but I know on my B17A1 which is OBD1 my VTEC will not engage at part throttle. So my guess would be your faulty Throttle Position Sensor is skipping in its voltage signal output or surging causing your VTEC to engage and disengage and what not... I would check that before checking your oil pressure switch since it is already a problem that needs to be addressed anyways...
DJ4Jesus77
Honda Civic (2001 - 2005)
Mar 18, 2011 02:45 PM
yeungkaho
Mar 21, 2007 04:59 PM
del Slo SiR
47
Jan 6, 2007 07:19 PM
egmatt93
Dec 5, 2006 08:29 PM
Cm91h22a
Sep 9, 2003 06:59 PM
