why is my timing belt tring to come off??????
Old Aug 13, 2005 | 06:21 PM
projectvrex's Avatar
Default why is my timing belt tring to come off??????
i have a 91 crx 1.5l and i replaced the stock motor with another stock motor waitng on other parts to arrive for the true swap it is imperative i get this car on the road soon......so i can start the interior work on it at a different location........the engine hasnt fired yet but in the attempts to start it the timming belt is tring to come off even though i have cycled it to try to straighten it??????
anyone know why this is happening......and any help getting this this to fire would be greatly appreiciated........
the engine ran when it was pulled from its old home and had no problems at all?????
and now for some god knowing reason it is giving me alot of problems.....
Old Aug 13, 2005 | 08:04 PM
RaysBoomBoomLude's Avatar
Default Re: why is my timing belt tring to come off?????? (projectvrex)
Its sliding off? thats really odd. does it have tension on the belt? is the CAM gear straight??
Old Aug 13, 2005 | 09:28 PM
4drEF's Avatar
Keyboard Humorist
Have you or anyone messed with the timing belt at all?
I'm thinking one of 2 things is wrong.
1) The timing belt isn't tensioned properly because either the tensioner pulley is bad or the belt wasn't tensioned properly when it was installed or played with.
2) One or both of the two alignment plates that sandwich the crank gear might be missing.
Old Aug 14, 2005 | 12:27 PM
Default Re: why is my timing belt tring to come off?????? (4drEF)
you were right the bottom sandwhicher on the outher wasn't put on when the cam gear went on thank you ...
VegaS10
May 20, 2013 12:05 PM
TravisCadello
17
Apr 18, 2009 06:18 AM
Stealthman80
Oct 25, 2005 09:12 PM
Ziggymidget5
Apr 20, 2005 03:23 PM
Shark Tank
Oct 18, 2002 12:08 PM
