SOHC GReddy dyno numbers
Old Aug 13, 2005 | 02:45 PM
nerdsports's Avatar
Default SOHC GReddy dyno numbers
I finally got around to dynoing my car after approx. 3 years of boost. It's been 2 years on this motor however.
95 civic hatch dx [completely gutted]
d16y7 block
d16z6 head
arp headstuds
b16 throttle body
greddy turbo mani/turbo
2.5-3' dp/exhaust
jrc 8" i/c
450cc [dsm's]
p28 -> crome pro [tuned my jose bellas of speedworx]
dx tranny
~9psi
1st run
2nd run
3rd run
most cars i saw dynoing made their highest numbers on the last run, apparently mine did not.
i just got a PLX M300 mounted in my car and usb datalogging port on the ecu. im going to raise the boost another psi or 2... keep an eye on the a/f and hopefully retune sometime soon on 12psi.
what do you think? /
Old Aug 13, 2005 | 03:38 PM
PA MATT's Avatar
Default Re: SOHC GReddy dyno numbers (nerdsports)
i put down identical numbers to your first run on 8 psi with a stock z6, 450's,fmic so I would say your numbers are average. Im surprised you didnt put down a few more horses with the large downpipe,tb, and added cr of the mini-me though. What was the temperature like? it was 100 degrees and very humid when i did mine.
Old Aug 13, 2005 | 03:45 PM
ATS*Mark's Avatar
OG triple OG
Default Re: SOHC GReddy dyno numbers (PA MATT)
on my first sohc setup stock motor with the greddy kit i put down the same hp numbers but with 10 more lbtq. good numbers
Old Aug 14, 2005 | 03:54 AM
nerdsports's Avatar
it was really hot and humid (it showered a few times while i waited to dyno)...
it seems my #s are about average so i'm ok. i actually just finished installing an EX/Si transmission, ACT XTSS clutch and Fidanza 7.5lb flywheel. feels freakin' great!!!
next is JG Edelbrock manifold... and a retune.
Old Aug 14, 2005 | 09:00 AM
PA MATT's Avatar
Default Re: (nerdsports)
a few more lbs should get you to about 200, what fuel pump are you running?
Old Aug 14, 2005 | 09:10 AM
SOHCmaster's Avatar
My buddy after going NepTune jumped up to 264hp@12psi with greddy kit and 550cc on a Z6..
But he is on the 19c, not the little 15g
Old Aug 14, 2005 | 09:53 AM
VTC_CiViC's Avatar
Default Re: (PK SPEED)
My buddy's hatch made 201whp/180wtq yesterday at Lujan as well, 10psi on an Apex'i kit.
Other experiences: stock D16Y8 on a GReddy kit with a 3" exahust, Hondata, tuned my Frank @ SFP- 217whp /186wtq @ 10psi
Same motor (only now 140k miles), another GReddy kit w/ open DP, Uberdata tuned myself, 165whp (don't recall the wtq) @ 5.5psi
Keep in mind, IIRC the Z6 head has a larger combustion chamber and will yield lower compression, that along with the Y8's better IM design is why I typically see Y8's spitting out better numbers than Z6's or atleast Z6 heads.
Modified by VTC_CiViC at 4:54 PM 8/14/2005
Old Aug 14, 2005 | 12:42 PM
nerdsports's Avatar
Default Re: (PA MATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">a few more lbs should get you to about 200, what fuel pump are you running?</TD></TR></TABLE>
forgot to mention... walbro 255 intank.
streetlvlhatch
Apr 22, 2004 06:33 AM
Pfieff
Feb 18, 2004 05:58 PM
norcalcrx
Mar 20, 2003 05:49 PM
donnie B
Jan 6, 2003 05:33 PM
JFK78
Apr 10, 2002 03:49 PM
