LSD
Old Aug 13, 2005 | 10:47 AM
93b16CivicSi's Avatar
Default LSD
Can you buy a LSD and swap it into a ls tranny? just curious.
Old Aug 13, 2005 | 11:50 AM
5 Speed AP2's Avatar
Default Re: LSD (93b16CivicSi)
Yes.
Old Aug 13, 2005 | 11:52 AM
Default Re: LSD (5 Speed Dc2)
Quaife and Helical are two of the common brands. But there are more.
Have fun searching.
Old Aug 13, 2005 | 02:45 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Quaife and Helical are two of the common brands. But there are more.
Have fun searching.</TD></TR></TABLE>
i've seen the OEM LSD in LS's before, but that's gonna be alot more work.
Old Aug 13, 2005 | 09:28 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: LSD (ernald711)
i have a oem lsd, and im going to put it into my LS, why would it be more work then any other??
Old Aug 13, 2005 | 09:33 PM
Korch94's Avatar
Default Re: LSD (00IntegrAllmotoR)
the ring gear in an LS tranny will not bolt up to an oem type r lsd (unless of course it is a torsion lsd from a b16 tranny which is the only oem lsd that would work in an ls tranny)
assuming its a type r unit you would have to use the final drive out of a gsr or type r transmission to make it work in your ls
as mentioned you could use either a quaife, spoon, or any of the other LSD's made for the b16/LS tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Quaife and Helical are two of the common brands. But there are more.
Helical is not a brand of lsd, its a type.... as in helical---which uses gears to transfer power, viscous -- which is fluid based, and clutch type -- uses clutches to transfer power
Modified by Korch94 at 11:26 PM 8/13/2005
Old Aug 13, 2005 | 10:02 PM
kandyflip445's Avatar
Default Re: LSD (Korch94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Korch94 &raquo;</TD></TR><TR><TD CLASS="quote"> Helical is not a brand of lsd, its a type.... as in helical---which uses gears to transfer power, torsion -- which is fluid based, and clutch type -- uses clutches to transfer power</TD></TR></TABLE>
A helical is a TORSEN differential. I think you're getting torsen mixed with torsion. Torsion is a twisting force. Fluid based lsds are VISCOUS.
Old Aug 13, 2005 | 10:25 PM
Korch94's Avatar
Default Re: LSD (kandyflip445)
^^^^ right you are..... its a bit late and my brain is obviously partially shut down..........lol thanks tho
Old Aug 14, 2005 | 04:19 AM
hawjboi's Avatar
Default Re: (Palmy Blue)
well if your stock maybe an lsd isnt made for you but then again maybe its best...but when you start having more horse power ie. 300+whp how the hell do you get that traction put to the ground...and when it comes to the 1320 you want the lsd for both tires to spin for the best effieciency...yeah your tranny might still be spinning both tires but how long will it last before 1 tires starts to spin...
i'd say buy the quaife...
Old Aug 15, 2005 | 11:17 PM
Korch94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">IMO LSD is way overated and an expensive mod, people think its the best thing in the world but i dont think people realize what it is really made for... from what ive heard it seems people think it will help them have a better launch and stuff at the track but in reality its more used for cornering and other factors. My non lsd ys1 still leaves 2 nice black marks when i burn out, and i beat my friends LSD sentra SER off the line all the time, the funny thing is he complains about traction too lol</TD></TR></TABLE>
i don't really think that an lsd was meant to burn both tires.......perhaps it is for eliminating wheel-spin.
drag racers usually use spools but many use lsd instead, so don't go completely dismissing it as non-functional. yes a LSD is very functionaly in a road-race setting but it will defintely help your launch and 60' times. You don't really have to be making crazy amounts of power for it to help you out........
of all the things i have done to my car it is by far one of my favorites
Old Aug 15, 2005 | 11:31 PM
Kendall's Avatar
I've seen situations where people have dropped close to 3 seconds off of their times at some road courses by adding an LSD. Don't think for a second that it doesn't help in drag racing.
Old Aug 16, 2005 | 05:36 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">Im not sayin it dont help at all, its just not as great as people say it is... Hondas have no torque in the first place so its not like they are gonna be burning out much if you car is lightly modded.</TD></TR></TABLE>
Its the role of the transmission to mutiply engine torque by the gear ratios and apply it to the wheels.
128lb-ft*3.23*4.40 = 1819 lb-ft of torque applied to the wheels in a GSR in 1st gear.
I put an LSD in my car so that it wouldn't "burn out" as easily; I can actually give it gas in first gear on a wet road. It is one of the best mods that I put in my car.
DoWork17
Jul 9, 2009 07:32 PM
sixfourkiller
May 23, 2009 07:29 AM
Turbo92cx
28
Jun 23, 2007 01:14 AM
Vtecme92
Aug 3, 2005 02:46 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
