is this turbo ok for my b16?
Old Aug 12, 2005 | 11:47 PM
BrothaSit's Avatar
Default is this turbo ok for my b16?
i got this garrett turbo t25 off a i think its a turbo grand prix....everything is ok no shaft play, no cracks, etc...its a good turbo...but the thing that confuses me is its a .80 a/r...yep thats right a .80 A/R! most of my friends said it wouldnt work on my b16 it would blow up! but they are not sure about it tho...so do you guys think its ok? here are some pix of it...
Old Aug 13, 2005 | 12:13 PM
BrothaSit's Avatar
bump
Old Aug 13, 2005 | 05:13 PM
rkrone's Avatar
Default Re: is this turbo ok for my b16? (akitomoto)
it will work, that is probably from sr20det, not a grad prix, but you will make boost, but keep it low psi, i think that is about 7 or 8 stock, it does have a large ar, but it is a t25 which is kinda small, so it should in higher rpms
Old Aug 13, 2005 | 06:03 PM
project dc2's Avatar
Default Re: is this turbo ok for my b16? (rkrone)
its .80 AR is still smaller than a t3 63 A/r if u gonna compare sizes.
meanin those numbers are the T25 family. not the t3. totally different sizes
Modified by project dc2 at 3:46 AM 8/14/2005
Old Aug 13, 2005 | 06:28 PM
Bailhatch's Avatar
Default Re: is this turbo ok for my b16? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">its .80 AR is still smaller than a t3 63 A/r if u gonna compare sizes.
meanin those numbers are the T25 family. nomt the t3. totally different sizes </TD></TR></TABLE>
exactly. A/R is really the least important spec you need to know when hunting for a turbo, but for some reason they print it one the outside (its becasue thats the spec for the housing i guess..but still!!)...if they put lbs/hr that would be much more useful for all of you guys trying to use these factory turbos on your hondas.
Modified by Bailhatch at 11:12 PM 8/13/2005
Old Aug 13, 2005 | 06:47 PM
BrothaSit's Avatar
so this turbo would be ok for my b16? and thanks again guys for answering all my questions!
Old Aug 13, 2005 | 06:56 PM
JSpin's Avatar
Default Re: (akitomoto)
it will work just fine, just dont expect huge numbers out of it. it'll be kinda like driving an all motor honda with torque
Old Aug 13, 2005 | 07:04 PM
Bailhatch's Avatar
Default Re: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote"> it'll be kinda like driving an all motor honda with torque </TD></TR></TABLE>
until 6k... then it will feel like a big disapointment.
ever drive a 1.8t VW?
2000rpm- hey this is pretty snappy!....
3000rpm- holy **** this thing has some TQ! this is gonna be fun!...
4000rpm- what happened!?!
5000rpm- ummm, did a charge pipe come off?
6000rpm-[thinking of ways to get out of lease...]
Old Aug 13, 2005 | 07:39 PM
deca's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
that is so true.
Old Aug 13, 2005 | 07:47 PM
EBP.EM1's Avatar
LOL
Old Aug 13, 2005 | 11:01 PM
BrothaSit's Avatar
well im building my coupe for auto cross and i heard that people perfer the t25 cuz it spools quicker in corners.....
Old Aug 14, 2005 | 01:02 AM
BrothaSit's Avatar
the other thing is what kind of injectors you think you guys recommend? 310 or 450?
Old Aug 14, 2005 | 07:18 AM
Bailhatch's Avatar
I used to hit redline in 2nd all the time with my turbo D16 in Autox. I had a stratight T3 which is quite a bit bigger then your turbo, my engine was smaller and boost response was instant. Think about it, when are you actually under 3000 rpm in auto-x. That is the only place a mini turbo will help you. btw - I also ran a t25 like yours for a little while. It fell off 2000 rpm before redilne.
you can justify it all you want but that turbo is going to ruin your free-reving motor. At the very least get a straight T3 60 trim if you auto-x like every week otherwise a small hybrid is a MUCH better match for a street car.
Old Aug 14, 2005 | 08:39 AM
wantboost's Avatar
Who is Mr Robot?
that turbo is too small for a b16 and yes, when you are talking about a different class of wheels, ar is totally different.
do all of us a favor and nut check your firends and tell them how fuckign stupid they are
Old Aug 14, 2005 | 09:57 AM
Treblarefils's Avatar
"until 6k... then it will feel like a big disapointment.
6000rpm-[thinking of ways to get out of lease..."
This is what i was trying to explain to you..when we were talking about it but itll work.
Old Aug 14, 2005 | 10:47 PM
BrothaSit's Avatar
well thanks for the help i will try and get rid of this turbo asap now! might get the t3 or a t28....
lilrobie69
Apr 16, 2011 03:51 PM
airforce21
Oct 7, 2009 01:26 AM
darrell87
May 21, 2006 07:25 PM
dtown_racer
Apr 19, 2005 02:15 PM
7PSiEF9ZC
Mar 24, 2004 03:22 PM
