Running Rich..Help!
Old Aug 12, 2005 | 11:39 PM
panda714's Avatar
Default Running Rich..Help!
Hey guys, I got the P0172- System too rich CEL going on for about a couple weeks now.
I changed the Injectors, Fuel Pressure Regulator, Fuel Filter, Spark Plugs, checked my timing, swapped the ecu out, changed the map sensor, and purge solenoid.
Only thing that I haven't touched yet is the pcv valve and check for valve clearance/adjustment. The car is an EK with a b16a2. I'm also gonna check the wiring harness on Monday and see if there is any conductivity on the wires and make sure they are going to the right places. Anyways any help would be appreciated.
Old Aug 13, 2005 | 12:37 AM
Flashmn's Avatar
Default Re: Running Rich..Help! (panda714)
Did you swap the o2 sensor too?
Old Aug 13, 2005 | 02:11 AM
panda714's Avatar
swapped the o2 sensor also. OEM
Old Aug 13, 2005 | 10:52 PM
New2528's Avatar
I would check the Coolant Temp sensor and Intake temp sensor. Cuz if one of them are bad the computer would think that the car isn't warm-up yet, so it end up adding more fuel.
Bowl_of_Rice
Jun 17, 2011 09:23 PM
BEATurBOYS
Sep 18, 2009 05:25 PM
bec1488
14
Jul 11, 2009 11:39 AM
flatblacksleeper
May 8, 2009 11:27 PM
Maxime
May 17, 2004 11:30 AM
