wiring swap question
Old Aug 12, 2005 | 12:49 PM
jadsi420's Avatar
Default wiring swap question
im swapping 00 integra r engine into 99 civic si. i use the civic wiring harness as well as the si ecu correct? I don't use the jdm ecu that came with the engine.
just trying to cover my bases. thanks
Old Aug 13, 2005 | 08:11 PM
locash's Avatar
Default Re: wiring swap question (jadxi420)
Yes, use the 99 Si engine harness, and don't forget to either change the IAT plug/extend the harness, or use the Si intake tube and IAT.. Also, use the Si ecu temporarily, and then if the R ecu is a JDM version, you can get an OBD2b-2a ecu adapter and then use that ecu..
steroidguy
May 7, 2004 11:32 AM
poktan
21
Apr 30, 2003 08:50 PM
94CivSi
Jan 31, 2003 10:36 AM
spektrum
Nov 23, 2002 04:15 PM
The OEMobile
Nov 18, 2002 10:28 PM
