Egr help..bolt stuck
Old Aug 12, 2005 | 03:42 AM
vtec_crazy's Avatar
Default Egr help..bolt stuck
Hey ive been getting a code 12 EGR
ive taken one bolt off but the cant seem to get the second bolt near the intake mani off..
the bolts almost warn off ..
anyone got info how i can take it off still
thanks
MIchael
Old Aug 12, 2005 | 04:12 AM
syntax.'s Avatar
Default Re: Egr help..bolt stuck (vtec_crazy)
when i have a rusted/stripped nut i usually try going one size smaller with a 12 point socket and pound it on there real good, soak it down with some PB blaster, and it usually works. Dont forget to replace it with new hardware.
Old Aug 12, 2005 | 04:51 AM
red92s's Avatar
It seems like a lot of people have an isssue getting that frontside EGR nut off. You pretty much need to use a pivoting adaptor on a rachet the FIRST time, otherwise it will get rounded off.
I bought a set of bolt-out bolt extractors from Sears, and they got the job done.
Old Aug 12, 2005 | 01:14 PM
BB4vTak's Avatar
Default Re: (red92s)
yea easy outs from sears rock!!! you can totally round that bolt and these will take it out
Old Aug 12, 2005 | 04:54 PM
DarkBB4's Avatar
Default Re: (BB4vTak)
ok this is the way I know, that works
1/4 Drive Ratchet, 12MM SHItty socket (not craftsman) because they are thinner.... Use a 6" extention on the 1/4 inch and u should have the clearance
Old Aug 15, 2005 | 03:49 AM
vtec_crazy's Avatar
Default Re: (DarkBB4)
ok for some reason the bolts not coming off...ive tried everything..
now the bolts all shaven from me trying ..is there another way i can take out this friken bolt my engine light wont go away
Old Aug 16, 2005 | 02:29 AM
vtec_crazy's Avatar
Default Re: (vtec_crazy)
bump
Old Aug 16, 2005 | 04:14 AM
syntax.'s Avatar
did you get a set of bolt-extractors? you can also try getting a "nut-splitter" but it might be too cramped for that
Old Nov 30, 2014 | 05:07 PM
Mike Danford's Avatar
Here's a set from Harbor Freight tools.
9 Pc 3/8 in. Drive Metric Bolt Extractor Socket Set
I'm picking these up in the morning to tackle mine.
chillerice
Suspension & Brakes
May 18, 2013 06:55 AM
ej888
Jun 12, 2010 08:28 PM
snatch
Apr 13, 2005 12:32 PM
hondacivic_si
26
Sep 4, 2004 07:28 PM
mr_mbuna
Feb 9, 2003 08:28 AM
