vafc install problems
Old Aug 11, 2005 | 08:46 PM
d15civ's Avatar
Default vafc install problems
ok, here's the link to my previous post in the EF forum, figured i should move it over here.
https://honda-tech.com/zerothread?id=1324053
ok i figured it out that i was reading the pins in the wrong order. i've got that figured out now and wired up the throttle sensor wire again.
here's some info on the car so hopefully someone can help me.
jdm d15b vtec
still running obd0
pr4 ecu
91 dx hb
with vafc unplugged, runs fine other than the map sensor CEL 8
if i plug in the vafc map CEL goes away obviously, but if i try to start the car, CEL comes on for 15, which is ignition signal output or whatever its called.
i need help people, ive looked around on here, pgmfi.org, d-series, honda-swap, homemadeturbo.com. in need of help. we've even looked over the wiring on a friends car, hes got the same engine, aswell running obd0. his car works great, mine does not.
Old Aug 11, 2005 | 10:39 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: vafc install problems (d15civ)
Sounds like you installed it incorrectly. Go over all your wires again.
DarkBB4
Dec 12, 2004 11:56 AM
TurboBumblBee
Nov 8, 2003 10:44 AM
.Beaver
Feb 11, 2003 09:08 PM
Grimm
Sep 23, 2002 06:07 PM
2000blacksi
Aug 27, 2002 10:28 AM
