f22 question
i have a 91 accord lx a/t
the dizzy on this perticular setup utilizes an internal coil.
yesterday at the junkyard i found a 93 lx that had a dizzy with external coil....
can and should i swap mine for that 1?
thanks in advance
thanks in advance
im not quite that stupid ....
i meant could i switch the entire distributor from mine with the internal coil to that 1 with the external coil as so long as i take the entire dizzy and coil from that 93....
basically i need to know if its swappable is it the same plugs on the dizzy harnesses etc?
and would it reep any benefits....
tia
tia
With The 93 accord it does come with the external coil. The easest thing to do is to buy a msd blaster and cap and do the same thing just get a better spark which equals more power.
FOR SALE******** 91 Honda Accord H22 Type-S swap 2 door coupe bronze color,black rota slips, Apexi WS exhaust, full MSD Ignition, Jun ECU, skunk 2 coilover package, sway bars Sparco seat with harness very clean garage kept 16K on engine. Royal Purple Oil changed every 1000 miles. 13.26 @103.5 mph $5500.00 Please call Matt 804-437-3386
thanks for the info but i didnt get the answer i needed
can i bolt on the 93 dizzy and coil and will the plugs to the new dizzy from the 93 be the same since i have a 91 w/ internal coil.
and also is there any benefit?
tia
Modified by se7enofseven at 1:46 PM 8/11/2005
tia
i've personally have done that swap and it works. except vice versa. My 91autoLX came with a dizzy w internal coil. new engine (from salvage yard) came with an external coil. ONLY in this generation accord can the dizzy's be swapped. I've verified that a few times. i dont notice any difference as far as power is concerned.
once i complete the swap could i just replace the coil with an blaster coil and get more performance?
or would i still need the msd cap and power tower?
cause if thats the case ill jsut buy the ******* msd cap and power tower and coil and call that a day
Charlie Moua
May 1, 2004 06:44 PM
gringo7718
Feb 14, 2002 03:42 PM
