Major cooling issues
Old Aug 10, 2005 | 08:37 PM
MeanD's Avatar
Default Major cooling issues
I have a EG hatch with a B16A swap up until a few days ago it was staying cool like it should unless i did an excesive long top end run. And i was fine with that. but in the last couple of days i have been driving to and from nashville everyday and it has been getting really hot sitting in traffic. when i get moving it does not cool back down it stays a little past 3/4 hot the whole way home. if i turn the heater on it does nothing for it. tonight i changed out the thermostat and pressure cap and put all new fluid through out the block and the radiator. please help any ideas
Old Aug 10, 2005 | 08:50 PM
MeanD's Avatar
Default Re: Major cooling issues (MeanD)
anyone please i need some help with this it is giving me a headache
Old Aug 10, 2005 | 08:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Make sure your fan is turning on. Check for leakage around your waterpump. I would bleed the system as well just to make sure.
B and B's Avatar
Loved
Community Favorite
Are you running the stock radiator? They're tiny. I got the all-aluminum ebay model, great fit and finish. Engine runs under half in Texas heat wave.
Old Aug 10, 2005 | 09:05 PM
MeanD's Avatar
Default Re: Major cooling issues (JDM_Ej)
no leaks and fan is kicking on it is the stock radiator but it there anything else that i can do for the time being until i get my new radiator
GdmLaz's Avatar
omg the stock radiator does the job unless ur racing for lyk 5 hours reving to 9k rpms the stock radiator does just fine make sure u don' have no hoses leakin or leakin from the water pump worse case scenario look into ur oil and make sure theres no water gettin there and if there is u need a a new headgaskit
K2420
K Series
Oct 30, 2017 07:07 AM
fuglybutruns
Jul 28, 2015 07:50 PM
rktechteg
Dec 29, 2008 05:17 AM
Cyber ITR
Aug 7, 2007 10:48 PM
spock_rocker
Jun 6, 2005 03:32 PM
