Major cooling issues
I have a EG hatch with a B16A swap up until a few days ago it was staying cool like it should unless i did an excesive long top end run. And i was fine with that. but in the last couple of days i have been driving to and from nashville everyday and it has been getting really hot sitting in traffic. when i get moving it does not cool back down it stays a little past 3/4 hot the whole way home. if i turn the heater on it does nothing for it. tonight i changed out the thermostat and pressure cap and put all new fluid through out the block and the radiator. please help any ideas
HT Order of Merit
Re: Major cooling issues (MeanD)
Make sure your fan is turning on. Check for leakage around your waterpump. I would bleed the system as well just to make sure.
Re: Major cooling issues (JDM_Ej)
no leaks and fan is kicking on it is the stock radiator but it there anything else that i can do for the time being until i get my new radiator
omg the stock radiator does the job unless ur racing for lyk 5 hours reving to 9k rpms the stock radiator does just fine make sure u don' have no hoses leakin or leakin from the water pump worse case scenario look into ur oil and make sure theres no water gettin there and if there is u need a a new headgaskit
fuglybutruns
07-28-2015 07:50 PM
spock_rocker
06-06-2005 03:32 PM
