Honda S2000 Honda S2000
Convert 00-01 Rear window to glass
Old Aug 10, 2005 | 04:17 PM
KID808's Avatar
New User
Default Convert 00-01 Rear window to glass
Is it possible to change the complete top on the car?
Is there another way to do this? has anyone done it?
I know you can just buy a hard top but i found a really good deal on a 00
Old Aug 10, 2005 | 06:48 PM
spider2k's Avatar
yes. no. yes.
ive done it as have quite a few others. do a search on s2ki. you can either get a 02+ top and swap it with some minor mods or you can order one from some place thats sells on ebay.
Old Aug 10, 2005 | 07:00 PM
01itr320's Avatar
Default Re: (spider2k)
If you want, you can replace the factory plastic window with a new one. I believe it is a little below 200 bucks.
Old Aug 10, 2005 | 07:22 PM
SuzukaBlueAP2's Avatar
Default Re: (01itr320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01itr320 &raquo;</TD></TR><TR><TD CLASS="quote">If you want, you can replace the factory plastic window with a new one. I believe it is a little below 200 bucks.</TD></TR></TABLE>
me, personally, if I had an ap1 with the plastic window i would either swap to the top w/ glass window, or, if I wasn't concerned with the softop, buy a hard top.
Old Aug 10, 2005 | 08:09 PM
Francesco's Avatar
Default Re: (ScreaminTeg)
you need to modify the 00-01 frame, or you need to replace it witht he 02-03 frame...only two ways to do it
Old Aug 10, 2005 | 08:13 PM
jasonw's Avatar
http://cabrioworld.com/secure/...D=315
Old Aug 11, 2005 | 09:01 AM
ladius's Avatar
Default Re: Convert 00-01 Rear window to glass (KID808)
check out this thread from s2ki. no response yet on the results though.
http://www.s2ki.com/forums/ind...00638
Old Aug 11, 2005 | 11:43 AM
aklucsarits's Avatar
New User
Default Re: Convert 00-01 Rear window to glass (ladius)
I've never understood why everyone is so anti-plastic-rear-window... I mean, the older plastic design is lighter, gives a better view thanks to the larger size... It holds up pretty well. I mean, my plastic rear window is going on 6 years old and is still crystal clear and looks nearly new.
Sure the glass window gives you the advantage of a defroster. But I can't ever remember a situation where I would have needed a rear defroster on this car. And 90% of the time the roof is open anyway.
So anyway, I could care less what the rear window is made off...
Andrew
Old Aug 13, 2005 | 10:32 AM
2000S2000Mike's Avatar
Default Re: Convert 00-01 Rear window to glass (aklucsarits)
Seems like alot of money that be put to better use , but if it's what you want.
Old Aug 13, 2005 | 11:48 AM
KID808's Avatar
New User
I some what agree on the light wight of the window. I read a lot about the cars and it was everyones recomendation to get the glass window. I am close to making my purchase. I will probably go with a earlier s2000 with the plastic window. I might get a new piece of plastic if it is dirty/scratched. The ones i looked at seemed to be ok.
Thanks for all of your replys.
Let me know if anone tries the conversion from http://cabrioworld.com/secure/...D=315
Old Aug 13, 2005 | 12:03 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">I've never understood why everyone is so anti-plastic-rear-window... I mean, the older plastic design is lighter, gives a better view thanks to the larger size... It holds up pretty well. I mean, my plastic rear window is going on 6 years old and is still crystal clear and looks nearly new.
Andrew</TD></TR></TABLE>
Old Aug 13, 2005 | 08:22 PM
Francesco's Avatar
eh, i think the plastic is cheap...if you don't take care of it, it ends up looking like **** down the road...plus it folds in half when the top is down, so you have the seems from it folding...
imsebtactular
Honda S2000
Jan 22, 2010 07:34 PM
DevoS
Honda S2000
May 25, 2006 08:29 AM
S2Kingekstacy
Honda S2000
Jan 25, 2006 07:07 PM
Scotty B
Honda S2000
37
Nov 28, 2005 10:57 AM
eL_cArLos
Nov 14, 2005 06:13 PM
