Need some good turbo info...dont understand a few things....need advice...
Old Aug 10, 2005 | 04:14 PM
IntegraGSR(-1)'s Avatar
Default Need some good turbo info...dont understand a few things....need advice...
ok im trying to decide on which turbo to get for my build...heres my build incase you need to know
https://honda-tech.com/zerothread?id=1319694
but ive been looking at turbonetics turbos and there websire it very confusing to me..i have a chance to get a turbonetics t3/t4 from one friend...and a garret T4 from another..im looking to make around 400-450 with setup thats all i want really..so the turbonetics website shows the HP range on a t3/t4 at 200-550 and the T4 300-500...so its the plain obvious that the t3/t4 are noted for spooling hella fast and thats what i need for a street car, then why would you even get a T4 if a t3/t4 can make the same hp?????..
http://www.turboneticsinc.com/turbo_overview.htm
i know that the trim/AR/wheel stage and all that matter too..but the way it looks on paper is that the t3/t4 is the way to go , makes same power as t4 and prob spools faster...i guess i dont know enough about turbos to know any better..also i will prob have to run about 18-20psi to accomplish my goal that might play into affect too
ANY INFO WILL HELP ME THANK YOU!!!
Old Aug 10, 2005 | 04:42 PM
jdmturbosol's Avatar
Default Re: Need some good turbo info...dont understand a few things....need advice... (IntegraGSR(-1))
you might be able to make 450 on 15psi with a t3/t67
Old Aug 10, 2005 | 05:19 PM
SFWD 1934's Avatar
Default Re: Need some good turbo info...dont understand a few things....need advice... (jdmturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">you might be able to make 450 on 15psi with a t3/t67</TD></TR></TABLE>
You should be in the area of 440-460 with a T3/T67 w/stage 5 wheel at 15 PSI (on a 1.8-1.9L).
Jason
Old Aug 10, 2005 | 05:27 PM
Default Re: Need some good turbo info...dont understand a few things....need advice... (SFWD 1934)
t3/t67??? is that t3? gonna have to be a little more specific with this ole noob lol
Old Aug 10, 2005 | 05:30 PM
SFWD 1934's Avatar
http://www.full-race.com/catal...id=63
http://www.full-race.com/catal...d=468
http://www.full-race.com/home.php
Look at these.
Jason
almostboostedgsr
Apr 9, 2007 08:18 PM
Mugencrxsir1
Feb 26, 2006 04:17 PM
turbospool
Mar 24, 2003 02:05 PM
