Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
spherical bearing noise??help
Old Aug 10, 2005 | 10:25 AM
R91Si's Avatar
Default spherical bearing noise??help
have bearings (progress) on the radius rods on my 91 hatch and they seem to creak...there is no play in them but if you push up and down on the radius rods with car in the air they seem to "knock"...yes eveything is tight and when i installed them about 7000 miles ago they didnt do this...anyone else experience this?
Old Aug 10, 2005 | 10:31 AM
thawley's Avatar
Default Re: spherical bearing noise??help (R91Si)
Yeah, they all do that. There's a reason manufacturers use rubber bushings for street cars...
Old Aug 10, 2005 | 10:35 AM
577HondaPrelude's Avatar
Default Re: spherical bearing noise??help (thawley)
hit it with some WD-40 to get rid of the creaking.
After 7K miles they might be getting worn, and the only way to fix that is to replace them.
Old Aug 10, 2005 | 10:42 AM
thawley's Avatar
Default Re: spherical bearing noise??help (577HondaPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">hit it with some WD-40 to get rid of the creaking. </TD></TR></TABLE>
I disagree. An oil-type lubricant will attract grit to the bearing surfaces and cause them to wear faster than they do already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">they might be getting worn, and the only way to fix that is to replace them.</TD></TR></TABLE>
This is true. You don't need to get the replacements from Progress. Just remove C-clip that holds the rod-end/bushing into the race and take it to any local industrial bearing house. Buy spares. They're pretty cheap.
Old Aug 10, 2005 | 02:11 PM
HapaHaole's Avatar
My experiece with spherical bearings in the suspension joints is that at high speed tracks like Willow Springs, they tend to wear rapidly. After a weekend and a half at Willow Springs, my front lower inner bearing expelled all its gutts. The rear actually didnt have to be replaced.
its a wear item now! might have to replace it.
Old Aug 10, 2005 | 02:13 PM
EdoMoto's Avatar
Default Re: spherical bearing noise??help (BSME)
Thats why I run High quality stainless bearings rated at 26000lbs each and are NON teflon lined so the teflon doesent come out of the bearing.
Edo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSME &raquo;</TD></TR><TR><TD CLASS="quote">My experiece with spherical bearings in the suspension joints is that at high speed tracks like Willow Springs, they tend to wear rapidly. After a weekend and a half at Willow Springs, my front lower inner bearing expelled all its gutts. The rear actually didnt have to be replaced.
its a wear item now! might have to replace it.</TD></TR></TABLE>
Old Aug 10, 2005 | 02:19 PM
R91Si's Avatar
yea only the drivers side is doing it...i like the idea of replacing just the bearing...
Old Aug 10, 2005 | 07:05 PM
Crx Jimmy's Avatar
sorry to jack the thread but i couldnt find those sperical bearings on progress website a lil help please finding them, link please
Old Aug 10, 2005 | 07:24 PM
TimeRacer's Avatar
Default Re: spherical bearing noise??help (Crx Jimmy)
They do wear out. You have two options when you start getting play. Either get the teflon sleeved ones and/or getting the rod end seals. The seals will help a bit and extend the life of the rod end by hopefully keeping the dirt out.
Old Aug 10, 2005 | 07:56 PM
eg6vtec1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, they all do that. There's a reason manufacturers use rubber bushings for street cars...</TD></TR></TABLE>
That's funny the Evo 8 has sphericals they don't have any problems. As for the progress kit they use a soft mild steel with a very thin wall and loose clearances on the misalignment's which can not withstand over torque the bolts without damage, as for the bearings they use the teflon liners fail then you have metal against metal which will squeak and also becomes very loose which will cause a lot of knocking.
so as long as you use a good bearing with a high quality liner, and misalignment's with a sufficient wall thickness that can handle the loads you will never have any problems.
Old Aug 11, 2005 | 01:17 PM
R91Si's Avatar
call progress direct or livermore performance...
Old Aug 11, 2005 | 01:18 PM
R91Si's Avatar
gotta find a good bearing place...hopefully theres one in tampa...
Old Aug 11, 2005 | 05:21 PM
KekeK_5G's Avatar
eg6vtec1....have you ridden in any Evo's? These things make more noise than you can shake a stick at...mine does anyway
Old Aug 11, 2005 | 05:38 PM
.RJ's Avatar
.RJ
Default Re: spherical bearing noise??help (eg6vtec1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">
That's funny the Evo 8 has sphericals they don't have any problems. </TD></TR></TABLE>
They'll last longer if they're greased and have dust seals.
Old Aug 12, 2005 | 05:55 AM
Todd Reid's Avatar
Default Re: (KekeK_5G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KekeK_5G &raquo;</TD></TR><TR><TD CLASS="quote">eg6vtec1....have you ridden in any Evo's? These things make more noise than you can shake a stick at...mine does anyway</TD></TR></TABLE>
mine does too. 27k miles on my EVO. not loud enough to hear when regular driving, but they pop and clunk a bit when moving the car around in the driveway, etc.
these types of joints will make more noise compared to conventional rubber bushings, etc. i consider that would be of no concern in a racecar! if you have these kinds of joints on your car, inspect them on a regular basis for wear and play and you should be OK.....
todd
Old Aug 12, 2005 | 04:52 PM
R91Si's Avatar
Default Re: (Todd Reid)
yes...not while driving....when you pull into a space or driveway...there is no play foreward or backward...only if i push up or down on the radius rods...of course my setup is g.c. 600 f/650r with koni's urethane bushings with exception of front control arm and radius rods metal...22mm rear sway and 19mm front...
Old Aug 12, 2005 | 07:41 PM
eg6vtec1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd Reid &raquo;</TD></TR><TR><TD CLASS="quote">
todd</TD></TR></TABLE>
Well if your hearing clunking noises there has to be play which means there's damage, If there is no play or damage, its imposible for there to be any noise, yes it's a litte more harsh on bad roads but its not all that bad, it wont ever make poping noises. You might want to check the rest of you suspension.
Old Aug 16, 2005 | 05:45 PM
R91Si's Avatar
Default Re: (eg6vtec1)
nobody happens to have a part number do they for the radius bearing?
Old Aug 17, 2005 | 11:36 AM
Johnny Mac's Avatar
Default Re: (R91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R91Si &raquo;</TD></TR><TR><TD CLASS="quote">nobody happens to have a part number do they for the radius bearing?</TD></TR></TABLE>
I will check the bearing size on Friday and give you the part number for the sphericals. I'll look up some different bearings and show a price and some static strength numbers.
Old Aug 17, 2005 | 02:33 PM
ENDLESS9's Avatar
This is what we use on our car and has not given us any problems, yet. Formula link kit.
http://www.technicasport.co.jp/eng/kit.htm
cusco has a kit too, but I do not know so much about it.
Nhilcrest
Apr 10, 2011 12:23 PM
RACEPAK
Nov 3, 2008 06:52 AM
01em2
Honda Civic (2001 - 2005)
Jan 30, 2008 02:33 AM
EG6_DREAMS
Sep 13, 2007 08:55 PM
cueballsi
Feb 18, 2005 06:21 PM
