over rev. shift from third to second at redline
Old Aug 10, 2005 | 08:36 AM
importfan0103's Avatar
Default over rev. shift from third to second at redline
was timing my car last night and finally got it where it was running best and took it out for a spin and shifted from third down in to second at redline.
I started to decelerate the car and then it just died.
Car is getting spark to all pistons, fuel pump is working(whines on as i turn the key to start and relay clicks), checked all related fuses. Changed out the distributor to a different one just in case still nothing. Car will pop start and run for like 30 seconds then die. Seems like its not getting fuel. but smells strong of it.
Im so pissed but im all to blame... what to do someone please help!!!
Old Aug 10, 2005 | 09:59 AM
EK k kay's Avatar
Default Re: over rev. shift from third to second at redline (importfan0103)
So you shifted from 3rd redline to 2nd, left it in gear, and decelerated?
Old Aug 10, 2005 | 02:23 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfan0103 &raquo;</TD></TR><TR><TD CLASS="quote">shifted from third down in to second at redline.
Did you bend any valves? Compresion and/or leakdown test?
Old Aug 10, 2005 | 02:31 PM
loodood's Avatar
valve float....that's what happened. a friend of mine did exactly the same thing with my last 98 prelude, and it cost me like $2500 to have someone else rebuild my head. your cheapest option is to find a rebuilt/used head rather than rebuild, unless you have alot of headwork already done. once you have your head off, check to make sure there is no damage to the pistons or cylinder wall; they usually hold up pretty well to this situation unless one of your valves actually broke off in there.
Old Aug 10, 2005 | 03:36 PM
Dogginator's Avatar
Daisy... Daisy...
Pistons, I'd like to introduce you to the exhaust valves. Exhaust valves, I'd like to introduce you to the pistons.
Like mentioned above, you probably bent the exhaust valves. From your story, it sounds like you had the clutch engaged for a while (a second is an eternity here). You're lucky that the engine still turns over, meaning that the bottom end is probably OK. If I were you, I wouldn't try to start it again. Instead, perform a compression check and prepare to pull the head.
What car is this?
Old Aug 10, 2005 | 10:47 PM
drdisco69's Avatar
Default Re: over rev. shift from third to second at redline (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">prepare to pull the head</TD></TR></TABLE>
And STOP TRYING TO START THE ENGINE. You broke it and it's not going to start. The ignition system is fine. Check the oil level to see how many pistons fell into the oil pan. Pull the spark plugs out, check the electrodes and peek in the cylinders with a flashlight. Do a leakdown test. And shift a little slower next time...
Old Aug 10, 2005 | 10:56 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: over rev. shift from third to second at redline (drdisco69)
You will be lucky if you didn't do major damage. A friend of mine did that in is 00 ITR. When we pulled the head half the valves were literally mashed into the head. We had to pick them out. Large hole in one piston and the others were scared. Cylinder walls were fucted. The entire engine was a loss.. at only 30k. Stop trying to start the car and pull the head... be prepared to spend serious $$.
Old Aug 11, 2005 | 03:48 PM
going to pull the head tomorrow morning, if the bottom end i sound thats great i have all the materials to rebuild the head(valves retainers,springs, cams etc) why wont it even turn over tho i mean it does pop start.
Old Aug 11, 2005 | 03:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote"> Check the oil level to see how many pistons fell into the oil pan. </TD></TR></TABLE>
What you mean by this?
Old Aug 11, 2005 | 03:52 PM
Default Re: over rev. shift from third to second at redline (wadup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wadup &raquo;</TD></TR><TR><TD CLASS="quote">So you shifted from 3rd redline to 2nd, left it in gear, and decelerated?</TD></TR></TABLE>
NO... i was going to shift to 4th slipped it in to 2nd by accident heard it rev way to fast pushed clutch back in.. then i braked slowed down and put it in second to drive back to where i was car started to bog then it just died in the middle of an intersection
Old Aug 11, 2005 | 03:54 PM
Default Re: over rev. shift from third to second at redline (Chiovnidca)
I spun the crank last night to see if i jumped some teeth on the camshafts which i didn't and to check tdc. The crankshft turns relatively easy.. no rods thrown tho.... what could cause this guess i wont know till i take the top off...
Old Aug 11, 2005 | 03:55 PM
oh and yeah all the plugs look fine.....
Old Aug 11, 2005 | 05:15 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfan0103 &raquo;</TD></TR><TR><TD CLASS="quote">What you mean by this? </TD></TR></TABLE>
I mean when the pistons fall into the oil pan, it will look like you have 6 or 7 quarts of oil due to the piston bits displacing the oil. I got a very confused phone call from a friend over this...
Old Aug 11, 2005 | 09:20 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (importfan0103)
pull the head, you bent valves, maybe cracked some valveguides, be prepared to spend some cash
Old Aug 12, 2005 | 05:35 AM
emrik's Avatar
the same thing happend to me this Monday. I reved up to 9600rpm in 0,3 sec /have a nice log file if someone wants to see/.
All exhaust walves are bent . Everything else looks OK.
HONDA_CIVIC_HATCH_Boy
Feb 27, 2006 06:17 PM
knightnam
Nov 12, 2005 06:26 PM
prendi
Aug 9, 2005 09:14 AM
nY's FiNeSt
40
Apr 1, 2004 08:21 PM
Yyz
Jan 27, 2002 09:15 PM
